Carburettors
Discussion in 'XJ Technical Chat' started by Mark62, Nov 9, 2018.
  1. Mark62
    Mark62 New Member
    United Kingdom
    Could someone please identify these carburettors , they are from my brothers xj750 trike he has recently bought . They are Mikuni and have the numbers 130 stamped inside, we need to repair one and think it might not be an xj750 engine .
    Any help greatly appreciated.
  2. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    Franz likes this.
  3. Mark62
    Mark62 New Member
    United Kingdom
    Thanks very much for your help.
  4. Mark62
    Mark62 New Member
    United Kingdom
    My carbs are only firing on the two outside one's any idea's why? Got sparks and new coils
  5. Simmy
    Stump told you but you're ignoring his link.
    Read the church page, it will provide very useful information for your problems.
    You're suspecting a fuel problem and I would agree. Time to dig into your carbs.
    Franz likes this.
  6. Mark62
    Mark62 New Member
    United Kingdom
    We have just found out that the engine number is not the original xj750 and has been replaced by a bigger engine . Now need to find out what engine and carbs we have. Also no sparks at the second and third cylinders .
  7. chacal
  8. Toomanybikes
    Tsawwassen bc
    Those looks like the Mikuni ones from a maxim “X” that are on my bench. Enrichment plungers horizontal. Carb hats have high tops.
    This is the xj700xn(us model) or Xj750xn (Canadian model) “X” water cooled motor.
    Only thing bigger is the xj900 air cooled engine.
  9. Simmy
    Mark is in the UK so likely a 750 RL or 900RK so mikuni’s make sense. Maxim-X pretty rare there. They do have gray imports though so still possible
  10. hogfiddles
    1985/86 xj750? If it's prior to that, the carbs should be hitachi..........so we need to know what the actual engine in it is. If it's bigger than the 750, it's probably a 900, but that's why we need the number that Chacal asked for.
  11. Toomanybikes
    Tsawwassen bc
    My 84 750rl has hitachi carbs.
  12. Simmy
    Now I'm confused. I thought the 84 750 RL was just a downsized 900 which would have mikuni.
    Now I understand why you suspected 750X
  13. hogfiddles
    '84 xj750rl is basically a 900rk, bbbut has a 750 engine in it. The x750rl also has Hitachi Carbs, NOT mikuni
    Years & Models: 1984 XJ750RL Seca models
    Carb Manufacturer: Hitachi
    Carb Series: HSC33
    Carb Model ID: 41Y00
    Main FUEL Jet Size: #106
    Pilot FUEL Jet Size: #40 or #41 (unsure which is correct)
    Main AIR Jet Size: #70
    Pilot AIR Jet Size: #225
    AIR COMPENSATOR Jet Size: not used.
    Starter FUEL Jet Size: #43 (non-replaceable, in float bowl)
    Main jet NEEDLE ID: #Y-18
    Main needle JET Size: #3.2mm (the main needle JET is also known as the "power valve" or "emulsion tube").
    Fuel Level in float bowls: 1mm +/- 1mm (.039" +/- .039")
    Idle RPM's: 1,050 rpms
  14. XJ550H
  15. XJ550H
    I think it was a 900 frame with 750 motor
  16. XJ550H
    could be bad pickup coil 2 & 3 use same pickup
    Mark62 likes this.
  17. hogfiddles
    Or a lead is unplugged… Gotta narrow things down
    Mark62 likes this.
  18. k-moe
    Correct.
