CARBY CONFUSION
Discussion in 'XJ Technical Chat' started by Antonio Debear, Oct 22, 2023.
  1. Antonio Debear
    Antonio Debear New Member
    CARBY CONFUSION
    DeAR Members ( BRAINTRUST ) Reposted
    RE: Kei hin carbs Model No VE64B AVL
    These Carbys have been fitted to a 1982 XJ750 RJ
    Bike currently being restored
    INFO
    These carbys have been cleaned in a sonic cleaner and reassembled.
    Have been put back and bike stated and seem to very effective.
    Carbys started leaking due to bowl gaskets not been replaced
    QUESTION'S
    I would like you guidance regarding the above bikes carbys.
    Could any one advise me regarding where i can locate the best place to obtain a set of gasket or original rubber seals for the bowl .
    Or should just make my own gaskets ( from gasket paper ) if so do you see any problems associated with this
    Any information or Diagrams or websites address would be greatly appreciated on these carbys
    The information that i can gather from the net is that these where original designed for 84-86 Honda CBX750 would you agree with this ?
    I have enclosed photos of the bowl and carbie for your perusal
    Thanks Tony Melbourne Australia
  2. chacal
    a100man likes this.
  3. Antonio Debear
    Hi mate .
    Thanks for the reply and i have checked these out.
    They certainly look correct
    The problem also is that there is little information on these carbs and i was wondering if the group had used them before or if
    anyone new exactly what bike these came off.
    I have written to some of the suppliers on eBay of carby kits for the 84-86 Honda CBX750 to find out
    whether the fit the Kei hin carbs Model No VE64B AVL.
    But as usual i received no response. I have contact about a dozen with no response
    I have also written to Astemo - Keihin North America requesting information and awaiting reply
    I will keep trying and hopefully will be able to recieve the information
    Thanks again for info
    Tony
  4. Minimutly
    Minimutly Well-Known Member
    West Wales, uk
    Well hell, what are you going to use for jetting? You will have to start from scratch and spend a fortune on different jets.
    Or go with what you have if its close enough?
    By some Hitachis..
  5. a100man
    a100man Well-Known Member
    Bedford, UK
  6. Dave in Ireland
    Ireland
    I was closely acquainted with a CBX750 in the late 80s that went around the clock more than once. Bullet-proof lumps, made all the better by the hydraulic cam followers.
    Probably the only Honda of the day I'd have bought, and it's a pity the hydraulic followers didn't appear on other engines (apart from H-D, as the article suggests).
  7. Antonio Debear
    Hi Dave I will probably go with whats in there at the moment. As discussed in previous post the carbys were ok until they started leaking. However if i can find out the exact year model and brand of bike they came out of I will probably buy a carby kit.Hoping soneone out there might know
  8. Antonio Debear
    Thank you for the information MUCH appreciated. Added to my collection of info
