CB 750 coils
Discussion in 'XJ Technical Chat' started by Jetfixer, Apr 23, 2016.
  1. Dave in Ireland
    Ireland
    Prompted me to score another triple-pack of MT08 coils from the Gulp Whinge, a mere thirty bucks with leads and brackets.
    I think I've got enough now to see me out. These things last so long and work so well I've never had the urge to buy higher output so-called sporty coils.
    chris123 likes this.
  2. Chitwood
    Chitwood Well-Known Member
    Fort Atkinson, Wisconsin
    I just picked up and installed some cb750 coils on my midnight maxim. To my door 2 days early $27 for the pair. I was happy to be able to replace some cracked original coils and make new plug wires to go with my new ngk plug caps. Excited to get it tuned and see how it runs now
    Jetfixer likes this.
  3. Scott I
    Scott I Member
    wisconsin dells
    I picked up and installed MIC (made in You guessed it!) coils for a CB750 and installed them on my 750Maxim along with new NGK wires, caps, and plugs. Took it on a number of rides (approx 100miles) without issue so far. Was happy to get the new plug wires and caps going and just took the risk. So far so good. Install was easy, fit was the same as stock just upside down.
  4. Jetfixer
    I have almost 700 miles on my Seca with no issues with these coils.
  5. chacal
    Not really. The CB750 coils have the coil mounting holes spaced too far apart to fit any of the XJ700 models (especially the air-cooled ones, which mount the coils just outside of the steering headpipe). Although you could probably do a LOT of custom bracketry mods to get them in place, you'll probably: a) throw them thru a window before you actually get them to fit, and : b) realize you can't use the chrome coil covers anymore, which makes the coils stick out like a sore thumb.
    XJ700's (and other models that use "shorter" coils, such as FJ600 and FZ600 models) should stick with using the shorter coils, to save yourself a lot of headaches. But........the electrical specs are all the same, so if you do manage to get the "bigger/longer" XJ650/750/900/1100 coils somehow shoe-horned in place, you'll be okay "electrically" speaking.
    Franz likes this.
  6. Andy Dobkins
    Andy Dobkins Member
    Lonedell Mo
    Thank you glad to know before I order them
  7. JoeyXJ
    JoeyXJ New Member
    Thinking about doing this mod to my 1981 XJ750.
    Just curious about which wire goes to (+) and which to (-) on the CB coils.
    My current wires are
    - Left: red/white and orange
    - Right: red/white and grey
    Thanks!
  8. jayrodoh
    jayrodoh YimYam
    Cleveland
    Red/White are positive both sides.
    JoeyXJ likes this.
  9. Dave in Ireland
    Ireland
    While it might be handy for future troubleshooting...
    Doesn't really matter that much - on each double-ended coil, one plug will always be arse for elbow, which kind of makes a nonsense of polarity on the primary.
    JoeyXJ likes this.
  10. JoeyXJ
    JoeyXJ New Member
    Thanks gents
  11. Jetfixer
    What I did was desoldered leads off of old coils and crimped on blade connectors to the Honda coils , in this way it plugs in like stock . Used these coils on two of mt Seca 750's these work great almost five years of use.
    Franz likes this.
  12. chris123
    chris123 Active Member
    Benicia, ca
    Will the cb750 coils work on a yx600 (xj550)?
  13. Jetfixer
    They should it is easier to get them to work than Dyna coils .
  14. Arnaud
    Arnaud Member
    Netherlands
    I am hesistant to buy them used, some things like ignition parts have to be new to shut down problems..
    Are they new for sale, cheaper then xj900f oils (56 euro /piece)
  15. Dave in Ireland
    Ireland
    Just noticed I've been wrongly labelling them MT-08 coils for the past couple of years.
    Should have been MP-08, just to clear things up.
  16. Arnaud
    Arnaud Member
    Netherlands
    So, as i understand, the plugs are different.
    How about the color-codes?
    In other words; Which color wire goed on which Honda wire?
  17. Dave in Ireland
    Ireland
    Just for consistency, put the positive feed on the blue-green and the wire from the ignitor on the black.
    It makes no difference really, as it's a wasted spark system and one of the spark plugs will always be sparking the wrong way around. Nothing can be done about that, and it seems to make not the slightest bit of difference anyway.
    So, basically you can connect either tag to the feed and the remaining one to the ignitor - it's all the same.
    Franz likes this.
  18. Arnaud
    Arnaud Member
    Netherlands
    Another question,
    Original have our bikes 5 K Ohm spark plug caps.
    Which should we use with the CB750 coils?
    Does the TCI ignition need this resistance?
    I always thought the lesses resistance the better for the coils... and the resistance was not to interfere with radios..
