Changing the fueltap.
Discussion in 'Hangout Lounge' started by jim123, Dec 6, 2012.
  1. jim123
    jim123 Member
    Chicago,Il
    Is it just two bolts, wipe mating surfaces, and put new one on? The new one has an o ring gasket on it already and I have a new oval one from Yamaha. I'm low on gas and want to try is without making a mess.
  2. bigfitz52
    That's pretty much it; tip the nearly empty tank away from the tap and you should be able to do it with no spillage.
  3. jim123
    jim123 Member
    Chicago,Il
    Thanks.
  4. jim123
    jim123 Member
    Chicago,Il
    That was too easy. Every job on the bike should go like that.
