Changing Tyres With Wire
Discussion in 'Hangout Lounge' started by Franz, Nov 18, 2024.
  1. Franz
    Anyone tried this on a motorcycle?
  2. Fuller56
    Fuller56 Well-Known Member
    I have not but a riding pal of mine has and enthusiastically remarked about how easy it was. I tried and was too simple to figure it out and had the tire off with my spoons almost as quickly as this video shows. I will try it again with the next tire change.
  3. Brhatweed
    Brhatweed Well-Known Member
    Mora MN
    I use a vacuum pump to suck the sidewalls in, worked great for me.
  4. Melnic
    Melnic Active Member
    How does that work?
    For the video he did not apply anything to wet the bead before installing.
    for breaking the bead, I have a large C clamp. Something that does not take up much space and you can use for many other purposes.
  5. Franz
    I am going to try it but l think l will get a C clamp for breaking the bead too. Its certainly worth a try.
  6. Brhatweed
    Mora MN
    I just pulled the schrader valve out and used a small-ish vacuum pump and it pulled the sidewalls in bead and all, you'd be amazed at what atmospheric pressure can do in reverse.
  7. Fuller56
    I have 2 c-clamps that I have used for years to break the beads. 2 needed for the older, harder, more stubborn tires, with a board on the opposite side against the wheel rim.
    Franz and Timbox like this.
