Charging issue
Discussion in 'XJ DIY How-To Instructions' started by Chris gallipo, Jun 9, 2018.
  1. Chris gallipo
    Chris gallipo New Member
    Rutland, Vermont
    I'm trying to figure out why my xj550 has starting issues. It doesn't want to turn over easy. I checked the voltage on the battery and it was good at around 12 volts but after getting the bike started and checked it again while running it was still at 12 volts. Any idea what this could be. Thanks.
    sounds like you need new brushes they are located under the alternator cover if less than 11mm long the brushes will need to be replaced .
    clean copper rings with a hard eraser. then clean with electric spray
    go to this link you will find specs and tests near bottom of page
    sold by our supporting vendor www.xj4ever.com
    HCP215 Aftermarket ALTERNATOR BRUSHES WITH HOLDERS SET. Fits all 1982-83 XS400, XJ550, 1984-85 FJ600, 1986-88 FZ600, 1986-88 YX600 Radian, all XJ650, all XJ700, all XJ750, all XJ900, and XJ1100 models.
  3. Chris gallipo
    Rutland, Vermont
    I'll check that. Thank you.
