Cheap XJ700n Ignition upgrade
Discussion in 'XJ Modifications' started by capy, Jan 25, 2007.
  1. capy
    capy Member
    Florida
    I have modified my ignition sytem on a 85 XJ700n for $29.00. I have logged about 1000 miles on it and it has worked flawlessly. All you need is a set of 4, 7mm ignition wires and can of liquid rubber. It also fixes the minute cracks int he coil housing that are common on the coil packs for this model. I have a step by step detail in the blog area. Hope this helps someone.
