Choke question
Discussion in 'XJ Technical Chat' started by Jake750, Mar 18, 2021.
  1. Jake750
    Jake750 Member
    Detroit
    '86 yx600 Radian. Is it normal for the rpm's to continuously rise when the choke is pulled in?
    When I have the choke engaged the rpms just keep climbing as if I was hitting the throttle. I'm sure my neighbors dont appreciate the warm up process.
  2. Yammaat
    Yammaat Active Member
    Netherlands
    Yes, as the engine warms up the mixture gets more explosive.. hence more rpm.
  3. Jake750
    Jake750 Member
    Detroit
    It's normal for it to climb all the way to 8000?
  4. Yammaat
    Netherlands
    That I don't know but up to 5K would not surprise me at all.
    Jake750 likes this.
  5. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    yeh , my xj600 (same engine as yx radian) , i start it on 3/4 choke, then as soon as it starts (just about 5 secconds) i cut it down to half choke, otherwise the revs climb like you say, then i just keep fethering it in, till it ticks over nicely, the settings vary ,depending how warm it is outside
    by the way does the radian have the choke on a knob attached to the carbs, or does it have a cable , handlebar operated one , i ask because you may be having a sticky cable on the choke, resulting in the high revs.
    stu
  6. Jake750
    Jake750 Member
    Detroit
    Cable operated choke on handlebar
  7. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    feather the choke. I would never let my bike freewheel to 8000 rpm.
