Choosing the correct Oil for a wet-clutch Motorcycle
Discussion in 'XJ Technical Chat' started by k-moe, Jul 27, 2013.
  1. Yardawg
    Yardawg Active Member
    Hatch NM
    Oh then that explains it. I was looking at the wrong Rotella. Glad I didn't buy it
  2. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    Too many kinds of oil! Screw it, I'm going with vegetable oil!
    Yardawg and TheCrazyGnat like this.
  3. k-moe
    Castor oil is fine, so long as you're not planning on riding hard, or for very long between decokings.
    Show of hands. Who has torn down an engine JUST for the purpose of removing carbon and sludge?
  4. ShotCaller
    ShotCaller New Member
    Denver
    Rotella (nor any Shell product I can see) is on the PDF dated Nov 1, 2016. As k-moe mentioned maybe they didn't pay for the cert anymore. However did go hunting for JASO MA compliant oil.
    Currently picked this up (as written on the side)...
    Shell
    Rotella
    T4 Triple Protection
    SAE 15W-40
    On the back panel the bottle states "*Compared to prior Shell Rotella Triple Protection 15W-40" and later states, "Meets the performance requirements of: ... JASO MA/MA2 ..."
    Given the notes and compliance listing, seems like the right thing.
  5. k-moe
    It is. Shell is above-board when it comes to their claims.
    ShotCaller likes this.
  6. Chris Wathen
    Chris Wathen New Member
    Venice California
    K-Moe what is the weight that you would use for shell rotella on an xj750??
    Thanks Chris
  7. k-moe
    Conventional Rotella Triple Protection only comes in the one weight; 15W-40.
  8. kerriskandiesinc
    NY
    Why does no one recommend a 5W-40, or a 5W-50....if available, surely, that specification gives THE most protection/cold start protection.....cold start is, supposedly where 80% of engine wear occurs...I have always used the broadest range of protection available?
  9. XJ550H
    5W is for cold cold weather riding like below freezing
  10. XJ550H
  11. kerriskandiesinc
    NY
    Thats a very common misconception though, the 5 part is ONLY applicable upon cold start, like any modern multigrade, once the engine warms up...the 5W, 'magically' becomes 10W, then 15W, etc, etc, until it reaches 40 or 50W........IE: the broadest range of protection !
    Just wondered why no one else uses or likes a 5W-40 (or 50...if thats even available on this spec) multigrade oil.....?
  12. XJ550H
    yamaha spec is 10w30 for colder weather
    and 20w40 for warmer weather
    you can run what you want but do you really need the 5w spec?
    it gets minus 20 here I do not start my bikes over the winter
  13. kerriskandiesinc
    NY
    Lol!
    I HATE oil threads too, but, just curious as to why no one would consider a 5W-40 spec, thats all!
    Well, even though NY Winters can be pretty horrendous, most every cold start, unless the height of the Summer could be classed as cold...cold weather, that is, thus I'd always want that precious golden liquid to be flowing quickly, and freely around the engine.....cold start's ( allegedly) are where 80% of engine wear occurs...!
  14. XJ550H
    what do you pay and brand of your oil?
    I use rotella T3 Tripple (discontinued)and will be going to T4 when my case of oil runs out at 14$ a gallon.
  15. kerriskandiesinc
    NY
    I've been using Shell Rotella Diesel, for as long as it's been available, in 15-40 but lately 5W-40..although I DO think the sulphur content has gone down :(
  16. Connor Bunch
    Connor Bunch New Member
    Provo, Utah
    You say you used to use Rotella T4 15w-40, but now use 5w-40? Is that 5w-40 stuff you use simply another variant of Shell Rotella? I am curious what that oil you are using is and how much it costs.
    I'm literally heading to Wal-Mart right now and I am going to pick up a gallon of Shell Rotella T4 15w-40 for about $14.
  17. kerriskandiesinc
    NY
    Yes..
    the 'Old' Shell Rotella was a 15W-40.....which was fine, but I always thought it would be 'better' if it was a 10W or even a 5W
    lo and behold, the 'new' Shell Rotella is a 5W40... although, supposedly the sulphur content has gone down :(
    I've been using it for a few years now.....
  18. k-moe
    A lower sulphur content is not a bad thing. It does nothing to help lubricate, resist shear, or improve longevity of the oil.
    You may be thinking of ZDDP, which has been lowered, but not enough to be of concern for us.
  19. kerriskandiesinc
    NY
    That MIGHT be it, i thought sulphur was good for (coating?)cam bearing surfaces, and the like?....but, i might have gotten that confused with ZDDP......
  20. k-moe
    Seems lik you did. Sulphur is a naural component of crude oil, and is removed (to varying degrees depending on the end product) as part of the refining process.
