Chrome issue
Discussion in 'XJ Technical Chat' started by Brent NZ, Jan 16, 2021.
  1. Brent NZ
    Brent NZ Active Member
    Tauranga, New Zealand
    I just installed a new exhaust (with much cursing and one squashed and bleeding finger) & discovered a spot of peeling chrome. The exhausts have been sitting around for a couple of years & are in otherwise pristine condition.
    So the question is, can this be treated with paint or do I need to get the exhaust re-chromed? It's right under the engine so I'm thinking grey or silver high-heat paint might be ok.
  2. DaygloDavid
    DaygloDavid Active Member
    North Yorkshire (UK)
    Sorry, not sure what to do about the peeling chrome but am interested to know about the bike and exhaust system. What model is the bike and what make is the exhaust system, thank you.
  3. Brent NZ
    Hi David, the bike is a 1980 XJ650 Seca, exhaust was custom-built by Cycleworks in Wellington. It's going to be loud!
    A bit of useless information, the same person built an exhaust system for my first XJ650 in about 1987.
    Jetfixer likes this.
    A touch of paint won't hurt, but it's not really needed. Just remember that you'll have to scrub the rust off occasionally.
    Jetfixer and Brent NZ like this.
  5. DaygloDavid
    Thank you, that's one nice looking bike in the making.
    I've just fired up a thread to ask the question whether or not my XJ650 UK model is the same as a Seca.
    Jetfixer and Toomanybikes like this.
  6. Toomanybikes
    Tsawwassen bc
    Yes it’s the same bike
  7. Andyam5
    Andyam5 Member
    Luton, UK
    Almost
  8. Toomanybikes
    Tsawwassen bc
    Almost? Canadian bikes have the oil cooler . We don’t get the lights on /off switch that’s about it
  9. Mezzmo
    Mezzmo Active Member
    A bit of paint as you suggested and it will be fine. I would carefully remove the bubbled chrome by cutting around it. Reason is some rust might occur under the bubble. Remember to have rust you must have both air and moisture, removing one means there cannot be rust.
    Brent NZ likes this.
  10. Brent NZ
    Thanks I'll do that, was concerned rust would get under the chrome & start spreading.
    Mezzmo likes this.
