Clattering clutch or primary drive
Discussion in 'XJ Technical Chat' started by a100man, Jul 8, 2020.
  1. a100man
    a100man Well-Known Member
    Bedford, UK
    My Radian engined 550 has alwatys been clattery at tickover but now more so, althogh it quitens quite a lot when I pull the clutch lever in.
    I'm planning to top up oil to max as I recall BigFitz saying this helps and checking the clutch spring bolt torques - anything else to consider?
    a100man likes this.
  3. XJ550H
  4. a100man
    Bedford, UK
    Dowel is interesting. I didn't know that. Does it wear to oval? or ever 'let go' completely??
  5. XJ550H
    have not had to fix one , there is a thread someplace about it where just a new pin was installed to correct situation
  6. a100man
    Bedford, UK
    I see that dowel locates teh starter gear so if it does 'let go' it will be fairly obvious..
  7. Rooster53
    a100man likes this.
