Cleaning old tarnished Jets??
Discussion in 'XJ Technical Chat' started by Mathius, Sep 1, 2016.
  1. Mathius
    Mathius Member
    Alberta
    I'm just curious if anyone has a recipe to clean old tarnished jets up really nice?
    There was some scale on them. But vinegar, and baking soda got most of it. I let them soak in it a few hours.
    At this point I could run them as is.
    But to have them look brass again would just be a piece of mind.
    Any advice, or should I just say screw it?
  2. mlew
    mlew Well-Known Member
    Apex, NC
    If they are corroded bad just replace them. They don't have to be bright and shiny to work.
    If regular carb cleaner soak does not clean them its time for new. They are not very expensive.
  3. Mathius
    Mathius Member
    Alberta
    Actually they kinda are $50 a set isn't that cheap. I'm mostly trying to save my 43 pilots. Might have to flip the bucks on new mains.
  4. Mathius
    Mathius Member
    Alberta
    They aren't corroded though.
    I'm just a sucker for shiny stuff.. lol
  5. k-moe
    Berryman's Chem Dip.
    Mathius likes this.
  6. mlew
    Apex, NC
    Your are buying them in the wrong place. Amazon has a pack of 4 jets for less than 12$ shipped. Main or pilot.
    Berrymans Chem Dip is wonderfull stuff. Just don't put rubber parts in it.
    Jetfixer likes this.
  7. Jetfixer
    The old addage chrome won't get ya home. As long as jets orfice is clear good to go. If you insist take some metal polish and a dremel tool with a polishing pad get them nice and shiny put them back in .. and you will never see them again ... but only you will know what they look like lol
    Mathius likes this.
  8. Mathius
    Mathius Member
    Alberta
    I'll look into those on Amazon.
    I was gonna buy them here, and no offense to the big guy on here. But that price is steep.
    As for the shiny stuff, "Chrome won't get ya home" is my favorite saying. Along with, "at least you look good on the road side".. lol
  9. Toomanybikes
    Tsawwassen bc
    Another place to try is
    Jetsrus.com
  10. Mathius
    Mathius Member
    Alberta
    I did.
    They don't ship to Canada.
  11. Mathius
    Mathius Member
    Alberta
    Do you have a link??
    I looked on Amazon, and Ebay..
    I found nothing.
  12. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    If the stock jets are clean I would not replace them. At least you know they are perfectly made. I'm not sure I trust all the after market products out there.
    Rooster53 likes this.
  13. Mathius
    Mathius Member
    Alberta
    I'm actually just looking to go up a couple of main sizes.
    This bike has aftermarket air filter pods, and the baffles cut out of the exhaust. It had "dial a jets" on it when I bought it. But they were setup wrong, and I would rather just jet it properly.
  14. k-moe
    Dail a jets are awesome....when a fella needs to compensate for altitude often.
  15. Mathius
    Mathius Member
    Alberta
    They were old as dirt, and the cheap plastic ones from the 90's. Plus it only had 3, and the #1 carb was left out. (Not sure why it was left to burn lean?)
    But the compression on that cylinder was good.
    Dial a jets do work!
    I used to go sledding in the mountains a lot. Some of the guys I rode with ran them. I just packed a jet kit.. lol
  16. Simmy
    Chrome won't get you home but it might get you laid. ;)
    Mathius likes this.
  17. mlew
    Apex, NC
  18. Mathius
    Mathius Member
    Alberta
  19. Yardawg
    Yardawg Active Member
    Hatch NM
    Just an FYI, I'm running 122 main jets and 42 pilot jets on my xj750j. I have 4 into 1 Mac exhaust and PO had drilled the air box. Stock paper filter, and approximately 4000 feet altitude. My bike runs great with this setup
  20. Jetfixer
    I run 124 main 41 pilot stock air box and paper filter my 82 xj750r seca runs fantastic.Mac 4. Into 2 exhaust
    Yardawg likes this.
  21. Mathius
    Mathius Member
    Alberta
    I got them pretty clean today with an old toothbrush, and arm&hammer toothpaste. It worked like a hot damn!
    I cleaned my carbs really good tonight.
    I'm running pod filters, and 4 into 2 (12" inch) straight pipes.
    I ordered a jet kit on ebay tonight, gonna try 125 mains, and 42 pilots.
    I'm at 2200ft in my area, I think that should do it?
  22. k-moe
    How did you get the toothbrush into the jet? More importantly how did you get the toothpaste out?
    The outside being shiny dosen't matter one bit; it's the hole that matters.
  23. Mathius
    Mathius Member
    Alberta
    I didn't use that much.. The jets were pretty clean to start with. I just wanted to get the tarnish off.. But I boiled them after I was done to get any leftover toothpaste.
  24. Toomanybikes
    Tsawwassen bc
    I'm about a block from the border and have family just across in Point Roberts and not a problem for me.
    I'm guessing your not close enough to just rip down and get a post box
  25. Toomanybikes
    Tsawwassen bc
    image.jpeg Is this not clean enough?
  26. Mathius
    Mathius Member
    Alberta
    Yep that's purdy!.. lol
    I live in Grande Prairie, it's a bit far to just rip to Coutts for jets.
  27. Toomanybikes
    Tsawwassen bc
    That's just Honda brand carb and combustion chamber cleaner part #ca66916 available at car dealers also
