CLunk-clunk noise in front end
Discussion in 'XJ Technical Chat' started by quebecois59, Aug 30, 2016.
  1. quebecois59
    I tried the kicking test too yesterday with no results.
  2. hogfiddles
    Check your fender bolts, too..... Both sides as well as the fork brace bolts/nuts
  3. Toomanybikes
    Tsawwassen bc
    No problem if you like I'll take it off your hands, just drive it to Vancouver and leave it with me :) . Of course I'll pay you for it but with a problem like that it'll have to be cheap ;)
  4. Bushy
    Bushy Active Member
    Take the pads out push the cylinders into the caliper, put silicon goo on the back of the pads carefully put them back in, work the brake lever till it's firm, tie the lever to the grip and let sit overnight. And yes have the correct shims as well, no more noises. As they say ..worked for me. My pin holes are slightly ovaled as well.
  5. quebecois59
    I will try that and report any change.
  6. k-moe
    Also chck the fender. Steel fenders can crack, and then they rattle.
  7. quebecois59
    Mine is plastic, it was cracked , I fixed it two years ago.
    I tightened all bolts and nuts of the fender and fork brace, one was a bit loose.
    No change, still rattles.
    I'M tempted to put homemade shims as a test and temporary fix. If the rattle stops, I would order two shims with other rear brake parts. Or try the silicone goo trick.
  8. quebecois59
    WHat kind of silicone would you recommend for that use? I have a tube Dynatex black RTV silicone I used for the valve cover basket, is that good enough for that? I'm concerned with high temperatures.
  9. hogfiddles
    Xj900 fenders are plastic...... Same for the 750rl. There are other fenders that will also fit.
    Dave
  10. k-moe
    Fancy plastic fenders!? Luxury, that is. Why back when I was just a wee lad.....
    Stumplifter likes this.
  11. k-moe
    I've always used either the hi-temp red stuff, or Hylomar.
