Clutch bolt torque Spec for 550 Seca? Service Manual vs. experts
Discussion in 'XJ Technical Chat' started by 4nik8r, Mar 21, 2026.
  1. 4nik8r
    4nik8r Active Member
    Ottawa, ON, Canada
    My Service manual says 5.8 ft-lbs for the "clutch screw torque", which I assume are the 5 bolts with springs holding the clutch assembly and plates to the boss. Yet most experts on here are saying 7.2 ft-lbs. I don't trust the manual much, it does not even mention the one friction plate with the larger inner diameter and the associated zig-zag spring, nor where those go in the order of assembly. So, 5.8 or 7.2? Advice/debate welcome.
  2. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    5.8 ft-lb = 8nm
    7.2ft-lb is for the clutch cover bolts (which is the outer cover)
  3. 4nik8r
    Ottawa, ON, Canada
    Ok, but 8mm? The clutch assembly bolts are 10mm
  4. Rayzerman
    Rayzerman Member
    Ontario Canada
    Nm not Mm....
  5. 4nik8r
    Ottawa, ON, Canada
    Oh, see it now. Time for better glasses !
    Rayzerman likes this.
