Clutch Lever and Perch Size Mismatch
Discussion in 'XJ Technical Chat' started by Jmkrull, May 4, 2018.
  1. Jmkrull
    Jmkrull Member
    Minneapolis
    I’m having an issue finding the right size clutch lever. I ordered a perch off eBay and it says it was off an 82-83 seca turbo. No lever came with it. This perch is bigger than my maxim 650G (changed out the brake master cyl. For a seca for flat bars. Wanted a match and the old clutch perch had stripped threads, but I digress). Anyway, my old lever is too small. I also ordered a bikemaster one and it is still too small, even though it said it was for the seca turbo. Do you happen to know what I have for a perch or which lever would work? Thanks!
    correct lever for you year bike is available at dealership/partszilla for 13$
    LEVER L 2H0-83912-31-00
    if that is a seca turbo perch this is the part number available at dealership/partszilla for 18.27$
    LEVER L 10W-83912-00-00
    Jmkrull likes this.
