Clutch noise
Discussion in 'XJ Technical Chat' started by Dan Gardner, Jul 23, 2026.
  1. Dan Gardner
    Minneapolis, MN
  2. Timbox
    Sure you don't have a bird stuck in there? This noise just start or after maint? Could be a few things I guess, just never heard a high pitch sound like that. Could even be the clutch basket rubbing on something. Have you checked the oil for specs of metal? Good luck.
  3. Dan Gardner
    Minneapolis, MN
    The whole engine was rebuilt last winter. Didn’t start squealing until recently- after several break in oil changes. When it was apart I did a basic inspection of the little radial roller bearing and it didn’t seem thundered, but who knows. Maybe some debris from break in messed it up. I think next step is to tear in, have a look around, maybe just replace the bearing and see what happens.
    Timbox likes this.
  4. Dan Gardner
    Minneapolis, MN
    I don't think that it is the pull-out bearing anymore. The frequency of the squeal is 1-to-1 with engine RPM, and how bad it squeals is affected by engine load. So I think it might be the cylindrical roller bearing dingle at the base of the clutch basket.
    So now the plan is to tear in a little further, get the entire clutch basket out, and see what is going on in there.
    cds1984 and Timbox like this.
  5. Dan Gardner
    Minneapolis, MN
    I replaced the clutch basket base bearing and the pull-out bearing.
    Still making angry squirrel noises.
    Not sure what next move should be.
  6. Rooster53
    Timbox likes this.
  7. Dan Gardner
    Minneapolis, MN
    Thanks @Rooster53 !!
    That is a really good possibility. I will look for intake leaks now!
