Clutch slippage, 81 xj750 due to #3 not always firing
Discussion in 'XJ Technical Chat' started by Toddmotoman, Jul 7, 2018.
  1. Toddmotoman
    Toddmotoman New Member
    Dfw
    Clutch is definitely slipping mid to high rev then any gear, changed oil running 20/50 in Texas, I just bought this bike back to life periodically third cylinger not furring because the pipes not hot, and sometimes it is, can tell in power, any way wondering if this could be my base for clutch slipping, odometer 11k now, had 8 when I got bike 3 maths ago,
  2. Polock
    no
    even if the clutch plates measure in spec, the springs are probibally weak
  3. Toomanybikes
    Tsawwassen bc
    Make sure clutch cable has slack and not hanging up
  4. Hutch74
    Hutch74 New Member
    Wisconsin
    Anyone have suggestions as to a good replacement clutch kit for my xj750? Need a gasket as well...
  5. XJ550H
    easy steps first lube clutch cable and adjust with 3 mm play. check routing cable should enter frame on the same side as lever .
    20/50 oil is it wet clutch motorcycle oil Jaso rated MA/MA2
    www.xj4ever.com will have the correct parts for you follow link and send email for quote
  6. XJ550H
    #3 not firing? check sparkplug cap it is a resister cap ohm it, trim a little off spark plug wire, end may be corroded.
    also swap sparkplug #3 with #4 see if problem follows plug.
    next would be to check the air jets in top of carb and main and pilot jets for proper location. carb cleaning is in your future.
    have you checked shim clearances?
