Clutch Slipping
Discussion in 'XJ Technical Chat' started by Zachary Barton, Nov 3, 2019.
  1. Zachary Barton
    Zachary Barton New Member
    Washington DC
    (1982 xj650 Seca Non-yics)
    Hey everybody!
    I have my bike together but I'm starting to feel it slip when I really goose the throttle. It used to be very responsive and had good friction.
    I've never replaced clutch plates so, any advice?
    Should I just order new clutch plates and replace them or is there a trick to this? Any particular plates you recommend?
    Also, I'd like to upload photos to the showcase but I can't figure out where to upload.
    Any guidance would be great!
    -Zach
  2. cgutz
    cgutz Well-Known Member
    SE South Dakota
    Are you using the proper motor oil? Some modern oils are to slippery for wet clutch. Using JASO-MA rated oil?
    Franz likes this.
  3. XJ550H
    if you are using proper oil and have adjusted clutch cable and lubed it(it may be sticking)
    remove clutch cover and you would start by removing the bolts and springs measure springs see if they are in spec inspect bolts for streching.
    inspect discs and plates measure. replace if needed.
    or just install new setup when you have it unbolted
    this thread will give you an idea of what your looking at doing.
    CLUTCHES 101-Part 1: the 400/550/600s with pics
    Zachary Barton likes this.
  4. Timbox
    From what you are describing, guessing you changed oil recently and may have put the wrong type in. That or your pressure relief hole in the master cylinder is plugged or getting plugged not allowing the clutch to disengage.
  5. Toomanybikes
    Tsawwassen bc
    ??????? Master cylinder?????
  6. McTavish
    McTavish Active Member
    Daytona Beach, Fla.
  7. Timbox
  8. kerriskandiesinc
    NY
    I'm confused??......as an old timer, its easy done...are we talking about the cable/hydraulic XJ front brake set up here ( 750....650/550 purely hydraulic) or the cable only clutch ( in the gearbox).....??? ;)
  9. Timbox
    ^^^You my friend are right on...I am having a senior moment..... Sorry for the confusion...admin can delete my posts if they please...
    Franz and kerriskandiesinc like this.
  10. kerriskandiesinc
    NY
    Lol, I have plenty of 'senior' moments too!!
    Franz likes this.
  11. XJ550H
    I already forgot what we were talking about
  12. McTavish
    Daytona Beach, Fla.
    The OP has a clutch issue, A forum member, suggested the arch nemesis of Felix The Cat, "THE MASTER CYLINDER" was the culprit.
  13. kerriskandiesinc
    NY
    I was always more of a Boss Cat/Top Cat man, myself.......
  14. Zachary Barton
    Washington DC
    Y’all rock. I will inspect clutch ASAP.
    I did change the oil very very recently as the temperatures dropped.. And the clutch doesn’t seem to be grabbing as well ever since.
    I have a new lever and clutch cable (no master cylinder) so, what am I doing wrong with the oil?
    Unfortunately I can’t recall what type/weight of oil I used.
    What is the “right” kind of oil...?
    -Zach
  15. Zachary Barton
    Washington DC
    Or does this “wrong oil” hypothesis only apply to clutches with a master cylinder?
    -Zach
  16. kerriskandiesinc
    NY
    At the risk of imploding everyone's heads, in the 80's/90's when things were less clear, I successfully used both 'car oils' and cheap 'supermarket oils', in a variety of my motorcycles, with NO ill effects, to clutch or engine
    I will add, knowing how cheap those oils were, I changed them religiously at very low....sometimes < 2000 miles, believing that whatever spec oils you use, clean oil is ALWAYS better than dirty, degraded oil..
    I believe Yamalube 10-40? is a popular oil and 'weight'.....myself.....don't ask why, I use Yamalube too, but in 20-50 spec , I will say it SEEMS to lessen 'sprag/starter 'clutch slip, in these old< ancient...Yamahas
    XJ550H and Zachary Barton like this.
  17. Zachary Barton
    Washington DC
    Interesting.. it is an old bike so, I’d like to avoid any unnecessary stresses. I’m with you on the preemptive oil changes.
    I’ll get my hands on some 20-50 Yamalube ASAP. I think the engine calls for 3L of oil.
    You mentioned the starter. Can ‘wrong’ oil impact starter performance as well? What would that look/feel/sound like?
    -Zach
  18. XJ550H
    you need a wet clutch motorcycle oil with JASO specs MA/MA2
    I use shell rotella T4 it is a good price at about 15$ a gallon Jaso MA/MA2
    it is diesel oil
    the starter clutch could start slipping it will be anything from starter spinning to a can of rocks sound
    it can also make your clutch slip
    synthetic oil may or may not cause clutch and starter clutch slipping. some say yes some say no.
    I would advise if you used an automotive oil and /or a synthetic oil and things started slipping and making noise to switch back to a Jaso spec oil and see if the issues go away. let the oil drain when hot and drain for a while to get it all out change the filter or drain the oil from the cover.
    if you used a motorcycle oil that was synthetic and things started going bad, change it
    it is a cheaper check than replacing parts first
    now i want to add if the evil oil caused your issues you may be needing a new clutch anyways and if starter clutch started to fail it too. It may indicate worn parts and you will want to keep an eye on them . Just my thought on the parts
    Timbox likes this.
  19. XJ550H
    did you lube the new clutch cable?
    is it routed the correct way on frame?
    do you have 3 mm play at lever and perch?
    Brickiejase likes this.
