clutch spring length
Discussion in 'XJ Technical Chat' started by bensalf, Apr 4, 2018.
  1. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    so , whilst renovating my spare engine, I measured the old clutch spring length.
    Haynes manual states
    clutch spring free length-
    standard---------------42.8mm,,,,,(1.69 in)
    minimum--------------41.8mm,,,,,,,(1.65 in)
    old springs measured
    from 40.3mm to 40.78mm
    so out of spec
    ordered new clutch springs from ebay.... EBC ones
    new ones measured
    from 41.89mm to 42.06---------- WTF.
    ok so they're above minimum but not up to standard length---- sheesh, i'm going to use them anyway
    maybe Haynes is slightly wrong.
    stu
    corey manshack likes this.
  2. cds1984
    cds1984 Well-Known Member
    Perth, Western Australia
    The interesting thing about clutch springs is that the longer and stiffer they are the less likely your clutch will slip... so...
    If you look at the engineering behind it, it seems to be based on what can the bolts/hub can handle without stripping and/or snapping and then how much the clutch cable/lever/operator can actually handle to pull that sucker out and let the clutch slip when shifting...
    .. what was I talking about again... oh yeah... don't get too bent out of shape about the minute size differences of the springs, keep an eye on the plates, thats where the magic is at.
    Jetfixer likes this.
  3. bensalf
    yorkshire ,england
    yeh , thanks. plates are within spec. I guess that's why most modern bikes have hydraulic operated clutches.
    stu
  4. Toomanybikes
    Tsawwassen bc
    EBC ones may have a higher spring rate than oem ones so I would not panic.
  5. Ketchup
    Ketchup Member
    Texas
    Hello Bensalf,
    Ordered some EBC springs a while back and wondered the same thing.
    This EBC spring kit was for an XJ550, part number CSK14. The shortest spring of this kit was discarded and not used. They were about ~25% stiffer than the stock clutch springs - give or take.
    Spring Min: 40.89mm
    Spring Max: 41.73mm
    Spring Avg: 41.245mm ((sum of length of six springs) / number springs)
    Torque to proper inch pounds, and make sure all of the plates are aligned properly.
    No observable or measurable issues/problems with the EBC clutch springs VS stock 35yr old clutch springs. Clutch lever only slightly more difficult to pull - 3-5%? However, I've replaced the clutch cable and it basically glides like butter blowing all of the above referenced percentages clear out of the water. Very, very easy now.
    Skol,
  6. bensalf
    yorkshire ,england
    yeh, thanks lads,
    it is a fairly new cable , so I don't think there will be any problem.
    strange how they send the springs for my specific bike , but theres 6 springs in the pack , my bike only takes 5.
    same a few years ago , when I did my café racer, ive one left over from that set also.
    thanks stu
  7. Polock
    extra one is in case one is short :)
