Compression test question
Discussion in 'XJ Technical Chat' started by Baconbiker90, Apr 6, 2017.
  1. Baconbiker90
    Baconbiker90 New Member
    Chicagoland
    I have a question about doing a compression test on a yics motor. Now I'm sure no one does this but the thought came to mind the other day. Would it be necessary to blank out the yics passage to get a more accurate compression reading by further isolating each cylinder? Or is the passage small enough for it not to matter? Thoughts? Overkill perhaps? It's on a 82 xj650
  2. Metalliccurrent
    Metalliccurrent Member
    OHIO
    Interesting thought, YICS open or blocked won't increase CFM of air being drown in by the piston. I believe this passage is before (upstream) of intake valve. :)
  3. k-moe
    Compression should be measured under conditions that replicate a normally running engine. The specs assume that the engine is warm, and the throttle plates are open. If you block the YICS system you aren't simulating a normal operating condition.
  4. Baconbiker90
    Chicagoland
    Gotcha , thanks for replying guys. I just checked my valve clearances. Waiting for my shim removal tool to come in the mail today so I can get shim sizes. Anything else I should check while it's open?
  5. k-moe
    Shim removal tool:
    Lightcs1776 and Metalliccurrent like this.
  6. Baconbiker90
    Chicagoland
    I've seen this method on here and as I've seen ppl have there mixed reviews on the subject of sticking things in-between the valves for risk of either breaking off peices of carbon deposits around the valve seat and or breaking off peices of wire/ zip-tie whatever you use. I see you are confident with this method though and have been around for quite some time.
  7. XJ550H
    I have the tool, I tried zip ties, the wire is the way to go no doubt about it.
    reworking the wire is easy but the tool needs to be modified to work grinding down the sides. I use the 2 I have as paper weights
    Lightcs1776 likes this.
  8. dkavanagh
    Rochester, NY
    I tried the tool. modified the tool, still wouldn't work in some positions on the head. I went with zip tie and never looked back. If a bit broke off, it would melt and be expelled easily enough. Copper wire sounds good as well.
    Baconbiker90 likes this.
  9. Baconbiker90
    Chicagoland
    Well then, looks like I'll have myself a brand new paperweight waiting for me when I get home today. And as far as compression goes I did things out of order a bit. I did a comp test before checking my clearances. Results ranged from 119 being the lowest and 130 being the highest and the other 2 were just above 120. Low readings for a 650 correct? With what readings I got for my clearances does this seem about right or should I squirt some oil in there and see if rings may be stuck. Carbs have been thoroughly cleaned but did not break rack. I was sure to clear blockage in the starter jets in side the well in the bowls. But still have a bit of a hard time starting cold. And doesn't idle for shite. It's been real temperamental.
  10. Baconbiker90
    Chicagoland
    I'm hoping I'll find out more once I get those out of spec valves back to where they need to be and go from there I suppose.
  11. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    Well Bacon (your name is BACON!!!!!!!) you obviously have been lurking and reading so good for you AND welcome aboard.
    I have the tool, never modified it and use it. There are times when I have to reposition it as it doesn't quite find the lip of the bucket if you aren't lined up perfectly. Not a big deal for me, I sit on a chair next to the bike, not in a hurry and take the extra time.
    P.S. less of an opportunity to cross thread the spark plug hole. ;)
  12. k-moe
    I talk to mine nice so they won't get cross.
    Stumplifter and Baconbiker90 like this.
  13. Baconbiker90
    Chicagoland
    I like to whisper sweet nothings to my carbs in hopes that it will cooperate with me
  14. dkavanagh
    Rochester, NY
    I had issues with the tool on my 550 engine. I suspect larger engines use a different casting (but don't quote me on that). What got me was one of the bosses for a bolt.. don't recall which one. I just couldn't get the tool to line up properly for those close to that boss.
  15. PilotSmack
    PilotSmack Active Member
    Calgary, Canada
    I have only used a wire. Never had any issues. I have had a shim crack in half when I removed it, but no problems with valves, clearances, or compression weirdness resulting from the wire. My only compression weirdness came from a bad torque wrench.
  16. Baconbiker90
    Chicagoland
    I'm gonna give the tool a shot when I get home, see how much of a fuss it gives me. Seems like I might have bought myself a bunch of useless tools as I had bought the yics blanking tool as well.(I'm a big fan of having the right tool for the job). The bike has 15k on it currently
  17. XJ550H
    it is always a good base line if you do it before shims you get the pleasure of seeing it improve.
    if you want to treat stuck rings use atf and acetone mix 2to 1 ratio it will ffree them you may have to treat and retreat to get results..
    just putting oil in is to see if the rings are why you have low compression in the second test
    from info overload
    h) If the readings are below spec, then shoot about a teaspoon amount of motor oil into each cylinder, crank the engine over a few revolutions with the starter (to spread the oil around), and then re-test each cylinder using the above procedure.
    i) compare the two results and analyze.
    XJ650 and XJ750 air-cooled engines:
    Minimum: 128 psi
    Standard: 156 psi
    Maximum: 171 psi
    Max. variance between lowest and highest: 14 psi
    info over load also explains how to interpret your test results
    The Information Overload Hour
    Metalliccurrent likes this.
  18. XJ550H
    could you tell us comp for cylinder 1 2 3 4 to compare it to your valve clearances
    I would suspect cylinder 2 as the worst based on your clearances
  19. Baconbiker90
    Chicagoland
    Hmm well this kind of worries me a bit as 2 of the cylinders were within spec. And we're not anywhere near the standard and about 5 psi shy of the minimum.
  20. PilotSmack
    Calgary, Canada
    What were the numbers? You try the weak cylinders with oil as well? Engine warm?
  21. Baconbiker90
    Chicagoland
    Cyl 1. 121
    Cyl 2. 119
    Cyl 3. 130
    Cyl 4. 124
    I'm going to check again once valves have been adjusted. Hopefully an atf+acetone mix will help
  22. PilotSmack
    Calgary, Canada
    Battery fully charged? Butterflies wide open?
  23. XJ550H
  24. Baconbiker90
    Chicagoland
    Fully charged battery, airbox filter NOT removed, I will be sure to do that as well. Now I thought we wanted the tests to be as close to normal running conditions when doing this or is that for something else?
  25. XJ550H
    I go by the info overload method of testing. as long as you test the same way every time its all good.
    air filters can be dirty and restrict flow of air if you want to test with filter in it should be new.
  26. Baconbiker90
    Chicagoland
    Alrighty then, I will add new air filter to list of things to replace. I just blew it out with some compressed air.
  27. Baconbiker90
    Chicagoland
    Will 10g be ok or is that too thick?
  28. mlew
    mlew Well-Known Member
    Apex, NC
    A small flat screwdriver makes a good shim removal tool. Never had any luck with a round piece of wire. A thin pair of needle nose pliers or tweezers to pick the shim out. Wire could be used to hold the valve, I use a plastic wire tie for that.
    Wire or wire ties to hold valves open can dislodge carbon and give false readings when rechecking clearances.
  29. Baconbiker90
    Chicagoland
    Ok so shim is kinda stuck in the bucket..
  30. k-moe
    10 g will work.
  31. k-moe
    He was refrencing the bucket holding tool.
  32. k-moe
    There is a notch in the bucket so you can use the screwdriver to lift the shim.
    I prefer to use a magnet to remove the shim once it is loose from the bucket.
  33. Baconbiker90
    Chicagoland
    Alrighty, I was successful with the proper removal tool only because it helped keep the bucket pinned down while I used a small Flathead to pry up to pop it out ... On to the next one!
  34. Baconbiker90
    Chicagoland
    Will it be ok to leave the out of spec shims out while I rotate to the next valve or will this cause damage?
  35. k-moe
    You will ruin the buckets, and possibly score the cams if you do that, so DON'T DO THAT.
    Every bucket needs to have a shim in place when you rotate the engine.
  36. Stumplifter
    near Irma, WI
    Write down the clearances, write down the size of the shims (put them back like Kmoe said). Then do your figuring and if Lady Luck is on your side you can do the shim dosey doh. . . However you do need at least 1 extra shim to swap things around. :oops:
  37. Baconbiker90
    Chicagoland
    Wooo! Looks like I'll be able to do the shim dosey doh and only need to buy 1 shim....Not bad.
    Stumplifter likes this.
  38. XJ550H
    I picked up some plastic place holder shims from chacal. something to think about when it is time for the next time
  39. k-moe
    I snagged a bunch of shims on E-bay for $10 shipped. None of them that I could use to set specs, but all are useful for placeholders, and I can grind one thin enough to use if I ever find a zero-clearance valve.
  40. PilotSmack
    Calgary, Canada
    If you're going on a shim purchase spree, it might also be a good time to pick up a few sizes of valves that are close to tight, i.e., An exhaust at 0.16mm or something. They're relatively cheap, minimizes your downtime next time.
  41. hogfiddles
    Maybe, but in-spec is in-spec.
  42. Baconbiker90
    Chicagoland
    Sweet, thanks for all the advice good sirs. I'm going to call the bike shop down the street from me. They should have shims there.
