converting lights to LED
Discussion in 'XJ Modifications' started by SnoSheriff, Jan 21, 2006.
  1. jag33
    jag33 New Member
    How can I tell if I have a mechanical or elctrical flasher? I have an 83 XJ750K Maxim.
    Joe
  2. Robert
    If it is stock, it will be small, three contact black box about 50mm wide and 30mm deep by 45mm high. These are mechanical.
    Anything else will be aftermarket and it is quite difficult to tell if it is mechanical or electrical. You will have to take the numbers off of the unit and cross them with the manufacturer.
  3. maximontherocks
    maximontherocks Member
    Vancouver Island, BC (Canada)
  4. ZaGhost
    ZaGhost Member
    Dartmouth, Nova Scotia
    They would work but you would need to replace your flasher with a generic electronic one.
  5. PainterD
    PainterD Active Member
    St. Cloud, Minnesota
    I made my LED signal bulbs better by adding some tin-foil inside the housing to spread the light better. I carefully cut around circle of foil out and tucked it inside the housing. Than I just poked a hole in the center with a knife and spread the foil around the hole to replace the bulb.
    I've been using this trick on my car/truck tail lights for years to give them a better effect. It makes more light by reflecting off the foil for better light dispersion.
    Most headlight housings are chrome mirror-like finish on the inside to help reflect the light better (magnify it) so I figured it should work on signal lights too. It's a cheap easy way to get more light out of one bulb.
  6. EdinaDad
    EdinaDad Member
    Edina, MN
    Another trick to use to reflect more light is to use the aluminium tape. Not Duct Tape, but tape that you use to seal ductwork. It is fairly thin, and does a great job of reflecting light, heat, etc.
    I have used it on my garage door opener or anywhwere there is a bulb that doesn't use a reflector.
    Dan
  7. seca750
    seca750 Member
    New York
    I would love to switch to LED but it all sounds really confusing! I have a 81 SECA 750, what would I need to convert all the lights over?
    Thank You!
    nino
  8. Gwyndwr
    Gwyndwr Member
    Vancouver, Canada
    I just did me rear lights. Put in an integrated unit for an R6. I'll put extra LED lights on my hardcases once they're on. I got off easy because I've kept my regular signal lights on the front and they produce enough heat to switch the relay.
  9. SQLGuy
    SQLGuy Well-Known Member
    OK, seems a lot of people have talked about this, but I haven't seen a solution yet, so I'll take a stab:
    I finally got my bike back from the shop after it had been run over in a parking lot. One of the things I had done to save money (and hopefully power) was have the shop put on LED turn signals in place of the broken stock ones. I had them install a "plug ready for Yamaha" electronic flasher as well.
    As you might expect, the flasher was not plug ready for an XJ, and, after some playing around with it the tech cut out the old connector and connected the new flasher between Br and Br/W. So, now the turn signals flash (albeit a bit slowly for my taste) but the self-cancelling is gone.
    I opened up the old flasher and here's what I found:
    It uses a relay with an NC contact and two coils on the pole piece (one about 100Ohms, the other about .2 Ohms). There are also a 1200uF cap and 150 Ohm resistor, but these seem to be more for stabilization than for any flash timing purpose. There is no bimetallic element. My best guess on the operation goes like this:
    1. The handlebar switch has a two pairs of contacts in each direction. One pair switches conductivity between the Br/W of the flasher and the selected turn signals and leaves it there, the other momentarily connects Y/R and B to the cancelling unit, enabling it.
    2. Once enabled, the cancelling unit, which had been holding +12V on the C contact (Y/G) of the flasher relay, lets this contact float. This deengergizes the 100Ohm coil allowing the relay contacts to close.
    3. Once closed, the relay contacts provide 12V through L (Br/W) to the turn signal pair selected by the handlebar switch. The current to them flows through the heavier coil and opens the relay. Once the relay is open, current flow stops, so the relay can now close again, and we have a flash cycle, based largely on the magnetic field build up and collapse time of the heavier coil of the relay.
    4. Eventually one of two things happens:
    a) the cancelling unit's counters expire and it puts 12V back onto the C contact, energizing the 100Ohm coil and locking the relay open (no more flashing), or
    b) the handlebar switch is cancelled, which opens the contacts between the L contact (Br/W) and the turn signals (no more flashing)
    So, assuming I'm right (and I think I am pretty close), the easiest solution for self-cancelleling with LED turn signals would be to use another relay to switch the Br 12V to the electronic flasher based on the state of the Y/G line from the cancelling unit.
    Just connect the Br from the harness to the common terminal of the relay and connect the NC contact of the relay to the 12V input of the electronic flasher. Then connect the Y/G from the cancelling unit to one end of the relay coil and connect the other end of the relay coil to ground.
    Anyway, that's the theory. I will most likely test said theory this weekend. I'll let you know what I find out.
    On a related topic, I installed the 1157 LED subs for my taillight but now have my computer complaining about the TAIL being out. Someone mentioned back on page one that there was a way to disable this check in the instrument cluster, but didn't provide much detail. What specifically needs to be jumpered, and will this mod only disable the TAIL check or will it disabled multple checks?
    Thanks,
    Paul
  10. SQLGuy
    Arggh....
    I just realized that there's an even easier solution: Don't remove the original flasher, just add the electronic flasher in series on the Br/W line coming out of it.
    The original flasher should connect to the supply side of the electronic flasher, and the line running back to the turn signal switch should connect to the load side.
    The original flasher will then act as your switching relay to provide power or not based on the input of the canceller, and the electronic flasher will provide the flashing.
    I just wish I had looked into this before my mechanic had cut out the original connector.
    Update... nevermind. The current load through the LED turn signals is probably not enough to keep the flasher relay open, so I'm back to theory A (see above).
    Cheers,
    Paul
  11. turtlejoint
    turtlejoint Member
    hey sqlguy,
    thanks for all that research. i just ordered led turns and brakes for my bike and also picked up a smartblink. you think you could give me a starting point on the best way to integrate it? BTW i got the version without the brake output, mine will only be handling turn signals.
  12. SQLGuy
    That thing is really overkill/underkill for this application. A regular 2-pin LED flasher would be much easier (and probably cheaper).
    They don't have any speedo input, so I'm guessing they're auto-cancelling is just time based. If it were me, I'd return it and get the 2-pin.
    If you really want to use this, though, the easiest way is probably going to be to remove the original flasher and canceller and connect this one with:
    Orange - original flasher Brown
    Brown - original canceller Y/R
    Black - original canceller Black
    Light Green - original flasher Br/W
    Everything else unused, except that you'll also need to cut the black that goes to the turn signal switch and connect it to fused +12V instead.
    There may be simpler configurations that would work, but this is what comes to mind off-hand.
    Again, with this setup you will lose the original self-cancellation which is distance AND time based and get instead this time-based only cancellation. Also, this is all assuming that your original setup is comparable to the SECA 750 turn signal setup.
    Paul
  13. turtlejoint
    turtlejoint Member
    thanks sqlguy.
    i agree its pricey but i actually got one for 15 bux off of ebay shipped. and as luck would have it my auto cancel is already not working so i can only win with this thing.
  14. turtlejoint
    turtlejoint Member
    and actually the thing i forgot to mention was that this unit solves two issues.
    first, it eliminates the fast flash syndrome that goes along with leds
    second, it wil allow me to use my new turn signals as running lights.
  15. Ease
    Ease Member
    NL, Canada
    That's a great idea for the tail!
  16. RickCoMatic
    The Self Canceling Unit gets a signal from the Speedometer Head. It's also dependent on TIME.
    The SCU turns-off the Flashing Signal Light after 10-Seconds or 490 Feet of Forward Motion.
    At High Speed BOTH Motion and Time functions combine to keep the Flashing Light ON for Lane Changing and Passing.
    There is Sensor in the Speedometer that controls the Motion feature.
  17. SQLGuy
    What was this in reply to?
    I agree with what you're saying, which is why I wanted to maintain my self-cancelling capability and did this analysis. The Smartblink unit that turtlejoint was asking about only uses time - it has no speedo connection.
  18. SQLGuy
    My theory about the operation of the self-cancelling circuit seems to be holding up. I removed the tank to do this and some other work. The first thing I checked was to see whether there was voltage on the Y/G wire initially after turning on the ignition... there was. Then I switched on the turn signals, and the voltage on that line dropped to 0.
    I have now added a SPDT relay in series with the electronic flasher and driven by the Y/G wire. I have confirmed that, now, if I turn the ignition on with the turn signal already engaged to one side or the other, the turn signals do not flash, they only start flashing when I push the switch again to one side or the other.
    Pictures to follow, and, of course, it will have to wait 'til I have the rest of the work done (a couple of days, I hope) before I can take the bike out and verify that the self-cancelling circuit is indeed working as it should.
    I've also got the computer torn apart to check on the TAIL indication. Basically, the computer uses a .47Ohm resistor to check voltage drop from B+ on the line leading to the taillight. This should give about a .7V drop for the stock 1157's. I've replaced the resistor with a 3A rectifier, as this should allow the use of either incandescent or LED bulbs without any further changes in the computer and without disabling the check.
    By the way, while I've got the cluster apart, anyone here have any familiarity with replacing or restoring the stock gauge backgrounds? My warning center outline is a bit heat damaged, and all the red has faded from the gauge backgrounds. I did repaint the needles with flourescent orange, and they came out nice, but I'd like to do a bit more.
    Cheers,
    Paul
  19. SpoonDaddy
    SpoonDaddy New Member
    This Side Of Crazy
    OK I HAVE A 93' XJ600 Seca II
    I dont know about the self canceler
    Im not sure if i have one
    I dont think my turn signals have ever turned off by them selfs
    Im looking for front turn signals to be THESE
    or maybe some LED strips like These
    But Thats The General Idea
    Im trying to get away from ALL protruding peices
    I want it as Neked As Possible
    A Good Place To Start
  20. turtlejoint
    turtlejoint Member
    i was looking at those same options for leds but i didnt feel like they were visible enough for my taste so i went with these and i also have a led brake/license holder coming in to change the look of the rear fender.
  21. SQLGuy
    OK. I can now confirm that the stock flasher/canceller does work the way I thought it did.
    I built this relay setup to feed an electronic flasher controlled by the canceller circuit, and my LED turn signals are working just like stock - standard handlebar switch, and auto-cancel works.
    This is a regular two-pin electronic flasher (in this case, it's a Rumble Concepts, which I'm not too impressed with, as the flash rate varies considerably with temperature) connected to a Radio Shack SPDT 12V relay. The relay is connected so that the 12V supply to the flasher goes through the normally closed contact. The coil for the relay is driven by the canceller, with the other end connected to ground.
    You might want to use a more automotive-grade relay, as they might be more weather and temperature resistant, but this setup goes up under the tank, so it is somewhat protected. I more-or-less sealed my relay setup with a glob of RTV after I had finished initial testing.
    ... I'm still fighting with the TAIL sense circuit, though...
  22. SQLGuy
    Last bit in place: I've successfully modified my SECA computer to accept the LED tail lights by swapping rectifiers in in place of the original current sensing resistors. This will also allow standard 1157's to be installed without any further changes, and the checks and warnings (in case bulbs are out) still function.
    I'd like to write this and the rest of my "How to convert to LEDs and get everything working" info up for a FAQ post. I notice there are no "final" FAQ's. Is that part of the forum not used? What the process here?
    Thanks,
    Paul
  23. stereomind
    stereomind Active Member
    Tulsa, OK
    hey Paul, you can post a write-up in FAQ suggestions. The Final FAQ section seems to be just a reminder that no FAQ is ever final :)
    what you have going there is definitely FAQ-worthy. I'm sure a bunch of people here would love to go all-LED.
  24. RickCoMatic
    In this completely Public Forum, I would be remiss if I didn't caution you about Intellectual Property.
    There is little, if any, regard for one's Intellectual Property among those who endlessly surf for good ideas they might profit from in some manner.
    If this item of yours is Marketable; you should make an effort to protect your idea's, as expressed, by Copyright and the device by Patent.
    If its a "Better Mousetrap" ... make sure it's known, by all, that it's your mousetrap.
  25. rnice
    rnice Member
    SE Pennsylvania
    Wow. What an incredible thread. My head hurts after eating reading in one sitting. Lots of smart and creative folks in this forum for sure.
    One thing I thought went mostly un-noticed is todubbad's solution here, which would be incredibly cheap, easy, no messing with old flasher unit.
    It would not keep the auto cancel circuit working, but it wouldn't throw away amps as heat like any of the load-adding solutions would.
    Just wanted to bump it because its a good solution compared to adding power sapping resistors, or buying expensive chip based electronics or fabbing bread-board-originals electronics.
  26. bill
    bill Active Member
    Raleigh, NC
  27. KrS14
    KrS14 Active Member
    St Marys, Ontario
    I've just got this working with an electronic flasher (Thanx Za for the schematics!), one thing i saw, was that if the signals are flashing and you turn the ignition off, when you turn the ignition back on the signals are still flashing. Anyway around this? It's not a big deal, just thought i'd ask.
