Couple of questions
Discussion in 'XJ Technical Chat' started by Kenbo, Jun 15, 2007.
  1. Kenbo
    Kenbo Member
    Central Scotland
    OK
    I think I may need to rejet my carbs for two reasons.
    The exhaust is a 4 into 1 and have read in other posts that this will effect the carbs
    Allso I have non standard air filters fitted which gives me a bit of concern.
    So what size jets came as standard (1980 xj650 European model)
    When I took these off there is no kind of filter medium inside and I do not know if that is right or not.
    What is the trick to unclipping the chock cable? I am not shure if I m just being too gentiel with it.
    Throttle cable also hard to get to.
    While I am here thought I would post a pict of the fuse box.
    Those are 13Amp domestic fuse in the lid as spares. New box required during rebuild. I think I might build the one described on the xjcd
  2. Alive
    Alive Active Member
    Queensland, Australia
    If I were you I wouldn't be concerned about the jets at this point in time... Leave that until later.
    I would replace the pod filters and fuse box and go hard on the cables because they are relatively cheap to replace :)
    Good luck ;)
  3. RickCoMatic
    That ... right there ... IS ... why these Fuse Panels need to be yanked-out with extreme prejudice and sacrificed to the Gods of Volts and Amperes.
    A shot of lubricant and some needle-nosed pliers will help get the cable turned-round to slip the bullet out from the catch.
    Looks like your dance-card is filled-out for many moon's.
    I wish you well with the project. I hope there isn't anything to complicate matters during the restoration.
  4. Kenbo
    Kenbo Member
    Central Scotland
    Thanks guys
    Just what I needed to know
    Dancing whats that? The kids hide in a corner with embaricment when I get up on the dance floor. :lol:
