Cracked broken fins
Discussion in 'XJ Technical Chat' started by vashtsdaytona, Jun 3, 2020.
  1. vashtsdaytona
    vashtsdaytona Active Member
    Fargo
    Discovered this today probably been that way a while. Makes me a little sad. But either way I'm still gonna ride it. Do I bother doing anything with it? Try to drill the crack grind edges smooth? Leave it be? If she goes she goes probably swap motors if that were to happen.
    Ignore the dirty oilyness of it, leaking valve cover, very obvious leak. Replacement coming.
  2. vashtsdaytona
    Fargo
    I should say the biggest chunk missing the top one has been that way as long as I've had it. The lower missing and crack are new. Well recently noticed so I think this season
  3. hogfiddles
    There was a forum on rebuilding fins not too long ago
  4. vashtsdaytona
    Fargo
    I suppose a person could aluminium braze and build it up. Lower heat, but still that's a bunch of heat. Tig maybe, I've not had much luck with cast,
  5. hogfiddles
    Franz likes this.
  6. Simmy
    if its just a daily rat rider remove the remaining cracked portion and make sure no crack will propagate any further, something you've already suggested.
  7. a100man
    a100man Well-Known Member
    Bedford, UK
    A skilled guy can TIG as suggested. See Mezzmo's video or this one by Allen Millyard..
    For the layman a new head might be easier though.
  8. vashtsdaytona
    Fargo
    Mostly I guess I'm thinking will it hurt? I have tig I can big but would need practice and really would have to pull motor to get on its side.
    So of its not going to matter much if missing I'd run it as is.
  9. Jetfixer
    Or look for a used head and cylinder .
  10. Mezzmo
    Mezzmo Active Member
    Hi Guys,
    I did a fin repair on my engine recently, Check this link at around the 5 minute mark. Worked out perfectly.
    SQLGuy likes this.
