Cutting your own gaskets...ok?
Discussion in 'XJ Technical Chat' started by Deadulus, Jul 3, 2008.
  1. Deadulus
    Deadulus Member
    Dufur, Oregon
    Hi all.
    Is it ok to make your own gaskets for the fuel bowls on the carbs?
    One of mine was obliterated by a foreign object the last time PO put them together.
    I have the same thickness (pretty sure) gasket material onhand.
    It wont throw off measuring float levels will it...read somewhere +_ 1mm is vital.
  2. Polock
    i don't see why not, a thinner or thicker gasket would move the bowl but the fuel level is what counts
  3. leadboots
    leadboots Member
    aylmer ontario canada
    i cut my own with no problems
  4. Zookie400
    Zookie400 Active Member
    Connecticut
    DO IT!
  5. chadwickm
    chadwickm Member
    Wichita, Kansas
    STICK IT TO THE MAN!! ;-) I make the majority of my own gaskets.
  6. EdinaDad
    EdinaDad Member
    Edina, MN
    I need to make a gasket for the crank case cover. How do I cut it to match the inside shape? I can trace the outer shape to get that one, but, I am stumped about the inner one.
    And, what should i use for gasket material? Paper? cardstock? Cork?
    Or should I just use Yamabond?
  7. chadwickm
    chadwickm Member
    Wichita, Kansas
    What I do is I cut the outside shape then tape it to the piece I'm making it for. Once that is done, I take the handle end of a screwdriver and rub it over the interior contours. The process creates an imprint on the opposite (facing down) side that I can then cut around to complete the gasket.
    I'd recommend gasket material with some RTV to ensure a good seal.
  8. Deadulus
    Deadulus Member
    Dufur, Oregon
    Gaskets cut, and they fit like they were made for it......wait... they were!
  9. Zookie400
    Connecticut
    i like inking the flange and "stamping" the paper. cut it out, soak it with hi-tack and bolt it up. it wont leak...ever!
  10. Robert
    I tap the insides lightly with a ballpeen hammer. It leaves a clear impression to follow. Another option is to use carbon paper and tap the pattern.
    Do not use paper, it will leak. Use purpose made gasket material.
    This is a good question. Permatex makes an extensive line of gasket makers and gasket sealants. I'm sure some of them would work well but I'd suggest you do a little reading on their website.
  11. PainterD
    PainterD Active Member
    St. Cloud, Minnesota
    I've always made my own gaskets whenevr possible. I usually use an old cereal box to make them (Cherios, Wheaties, etc.) and it works well for me.
    I use water color paint on the original parts to stamp the pattern onto the cardboard, and cut it out with a razor knife. I almost always use RTV gasket silicone to seal things up when re-mounting the parts. So far, I've had great success doing it this way. >PD<
