Cylinder Juggs Seperating from Crankcase
Discussion in 'XJ Technical Chat' started by Franz, May 5, 2020.
  1. Franz
    The juggs are sticking when nearly off the engine on one of the twelve studs for holding down the cylinder head but l put some penetrating oil down the problematic one and leave it overnight. I am pleased getting parts separated with no damage.
  2. vashtsdaytona
    vashtsdaytona Active Member
    Fargo
    you've got the patience, you will succeed
    Franz likes this.
  3. Franz
    More progress. That sheathing was jamming some of the cylinder head holding down studs.
  4. jayrodoh
    jayrodoh YimYam
    Cleveland
    Awesome
    Franz likes this.
  5. Dave in Ireland
    Ireland
    We even had electricity, laddie.
    Franz and hogfiddles like this.
  6. a100man
    a100man Well-Known Member
    Bedford, UK
    Please put some thing under the cam chain to stop it picking up crud form the engine casing
    Franz likes this.
  7. Franz
    Good idea there is a small amount of it fell into the crankcase when l removed the cylinders. Going to replace both chains when l split the cases. I will get it meticulously clean before reassembly.
  8. a100man
    Bedford, UK
    Ah Ok - though it might only have been a tope-end rebuild - as you were!
  9. Franz
    The starter chain was hitting the crankcase so l decided to change it, the plastic guide, starter clutch and cam chain. Bike ran great but l had tiny pieces of plastic too a warning sign of the guide going to break up.
  10. bensalf
    bensalf Well-Known Member
    yorkshire ,england
  11. Franz
    Next task removing head to jugg studs. I am going to very carefully drill them square taking as much metal out without damaging the threads. Then l will use a hammer and punch around the periphery of the stud to close the opening and move the remaining stud away from it's threads so l can get acetone ATF mix down between the threads. Let it soak a day or two before trying to remove it.
    Dave in Ireland likes this.
  12. Franz
    Hi everyone not going as planned. Unable to remove damaged studs on cylinder head. What size of drill and tap should l use to refurbish thanks?
  13. Franz
    I was thinking of an M6 helicoil but I am not sure if there is enough metal to drill out a 5.2mm drill bit.
  14. chacal
    Franz, if I were you I'd be taking a 6-pack of beer, the equivalent of US $ 100 in cash, and that set of jugs to my local machine shop and strike up a deal to have that done properly.......lot cheaper than replacing a set of jugs!
  15. Franz
    Yes I am a Carpenter so I am better leaving this alone. I know your right Chacal thanks that is what I will do.
  16. vashtsdaytona
    Fargo
    Yes in your situation if budget allows, take to a pro. This motor really had some corrosion huh?
  17. Franz
    Worst engine I ever worked on from a corrosion point of view I mean vashtsdaytona. I just don't like giving up on things lol I am tenacious and I fix most things I work on. But it is a great engine mechanically and I need to make sure the head gasket seals so I am going to get the engineering shop to do it, I am not in a rush won't be on the road till 2021 at least.
  18. Dave in Ireland
    Ireland
    When I don't have the tool, and the tool is so expensive that there's no real prospect of buying one for the odd occasional job, I grudgingly pay the bloke with the tool to do it for me.
    Stings a bit, but it's not often.
    That applies to spark erosion equipment most of all, if that's what it needs.
  19. Franz
    Yes true l don't mind paying to get it sorted just my local place was shut. Once the spark erosion removes a broken bolt does the old thread remain or does it need re-tapped?
    What l have also noticed is that there is no wear that l can feel between the top piston rings and the top of the cylinders. There is a slight roughness due to carbon which l removed with a bit of wood. Don't know for sure what mileage my engine has done but the cam chain tensioner is fully extended.
  20. Polock
    cam chain guides? good bad or ugly
  21. Franz
    The guides look good. I have not checked the bores with instruments but l can still see cross hatching on them.
  22. Polock
    if the guides are good i wouldn't worry about the tensioner
  23. Franz
    Some photographs. Perhaps the guides are worn?
  24. Franz
    The chain is worn with the curve in it in the picture.
  25. Franz
    8 mm stud repair by shop to cylinder head. Engineer thought 8mm were better. More progress.
    chacal likes this.
  26. Franz
    Need stepped M8 to M6 ones now to go through head gasket.
  27. Franz
    Need stepped M8 to M6 ones now to go through head gasket. Or open up the holes in the head gasket with a Dremmel to take the 8mm studs.
  28. Polock
    WOW is that motor dirty :)
  29. Franz
    Yes it is l am splitting the cases but the dirt will be removed first. Don't want that in the oilways and bearings. Head is fine cam journals etc perfect.
