cylinder loss after driving 65-70 for 3min
Discussion in 'XJ Technical Chat' started by superdom, Jul 8, 2012.
  1. superdom
    superdom New Member
    King George, Virginia
    Ok hopefully someone can help me here. After driving bike at 65-70 constant throttle the bike starts to miss three cylinders work then 4th comes in then goes out i then pull over let idle for 5 min then all clyinders are back working again anybody have any ideas im so fustrated at this point!!!!!! :cry: This problem is on an 82 xj 1100
  2. fintip
    fintip Member
    Austin
    What color are your plugs? A little history on the bike?
    How far out are your mixture screws on each?
    Have you checked compression on the cylinders ever? (when/what #'s?)
    How old are the spark plugs? Did you ever replace them?
    When's the last time you did an oil change, and what's the oil level?
    Looking forward to hear what others say.
  3. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    Sounds. Like you have a valve that's too tight. Pull the valve cover and report what the clearances are.
    MN
