Dads 83 XJ650
Discussion in 'XJ Technical Chat' started by DadsXJ650, May 21, 2022.
  1. DadsXJ650
    DadsXJ650 New Member
    Alberta
    Hey guys as the title suggest I've gotten my dads 83 xj650 (Canada model). It last ran when he put it in dry storage what he says was 4 years ago ( I think its been like 10 years). Got the Haynes manual and have been working on it for a little bit. I had to rebuild the starter button before it would turn over. Then when started it would only idle for a min with choke and starter fluid. Installed a new ATO fuse box, cleaned the carb, changed some needles and jets with like for like replacements but she was clean and I was happy (I might be a sinner in the church of cleano_O) . Other photos I've seen on this sub looked similar in cleanliness. I adjusted the idle mixture screws to 3 turns out from seated. I put new fuel intake boots on as I was able to easily remove the bolts (read some people have issues with these) tightened to 7.2 lbs. Benched synced the butterflies. This morning I started the bike after installing the carbs, she didn't start on the first try and I used the started fluid. The bike would run with full choke and bog down without it for the first min, till it would idle. The idle revs up very high leading me to believe there is an air leak, but she is running off fuel and not needing full choke now. I didn't put the vacuum hose back on #3 boot, would this be causing the high rev and if so what should I run the vacuum hose to, as the tank is off and petcock removed. It revs up high enough on idle for me to be concerned and use the kill switch, it about 4000 - 5000 rpm. Just looking for advice and will probably post when I get stumped and what I find fixes my issues. This is my first bike and I'm not very experienced when it comes to carbs, fuel mixtures and engines so sorry if I make obvious mistakes. Thanks for reading!
  2. DadsXJ650
    Alberta
    For some reason I can edit the above post cause it says its spam like or contains inappropriate elements?
    Anyways like I said I am new to this. I adjusted the idle screw and its sitting about 1200 now. Will have to check recommended rpm from manual. Have to tune based on spark color as I don't have access to a colortube.
  3. Jetfixer
    The hose to from the number three cylinder goes to the vacuum port on the petcock , if you still have it that is. The port needs plugged.
    DadsXJ650 likes this.
  4. DadsXJ650
    Alberta
    Dont mind the mess
    If I want to order parts from xj4ever do I message chacal? I am just trying to get this bike road worthy to ride this summer and may do an overhaul in the winter.
  5. Franz
    Jetfixer and DadsXJ650 like this.
  6. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    If you have an aftermarket petcock that does not need the vacuum line, you must somehow plug the line before doing any tuning whatsoever. Some use a golf tee shoved into the line.
  7. SQLGuy
    SQLGuy Well-Known Member
    A more elegant solution is to go to an auto parts store and get their little "Help!" kit of vacuum caps, and put one of those caps on the port of the carb holder.
    Jetfixer, Franz and Huntchuks like this.
  8. Huntchuks
    East Rochester, NY
    Correct, for a more permanent solution (for riding).
  9. DadsXJ650
    Alberta
    Thanks guys. I've got the original petcock.
    So some up coming stuff I've got to do for the bike
    Install new seals on the forks
    Will i be able to use a 19mm hex with extentions as the damping rod tool, I can make the tool but would rather not. Will new seals and oil be enough or will I need other parts for the forks.
    Service break peddle
    The break peddle does not lift back fully when depressed leaving the break slightly on. Will simply cleaning the pedal and reinstalling it work, or is there something I should be looking for.
    Remove gas tank rust
    I was looking at using the vinegar and salt method with aquarium rocks for abrasion Followed by electrolysis and a marvel mystery oil rinse followed by a gas rinse.
    Currently the left signal is only illuminating solid when engaged, it did signal properly on other tests?
    Any help is appreciated, I can grab pictures of anything on the bike if anyone wants.
  10. JBurch
    JBurch Active Member
    Owego, NY
    Suggestion, when you clean the tank, instead of aquarium rocks, use #8 by 3/4 wood screws, you will find them MUCH easier to remove, they are magnetic and you can use a stick magnet to remove them.
    The rocks don't shake out that easy.
  11. Franz
    19mm hex for damping tool I am sure that is correct. Check the fork bushes worth replacing I don't think they are expensive. It is a drum brake so the lever on the drum is activated by the pedal via the adjustable rod. The bar that goes through the plate that fits into the drum and carries the shoes needs greased, and the pin the brake pedal is connected to needs greased. Push the lever forward which operates the brake shoes. It should return under the tension of the brake shoe springs.
  12. Rooster53
    More than likely the rear brake shoes are original and need servicing, the below link illustrates it can be a serious safety issue:
    https://www.xjbikes.com/forums/thre...r-brake-bike-owners-please-take-a-look.15874/
    Yours may just need some grease, but if you know those are original or don't know they have been changed then it's worth taking a look
  13. DadsXJ650
    Alberta
    I've gotten most of my steps done. Gas tank is mostly clean expect for some flash rust. Rear break pads changed, inspected drum and greased pedal lever. New tires mounted. One front fork removed:(. The bottom damper rod allen key will not budge. Its been hit with some heat and penetrate to no avail. Tried the torque gun despite being scared of stripping it didn't strip but it didn't budge. I have a extension with a 19mm hex in the rod but it wont turn either. I might try to bolt it to a board tomorrow but the torque gun did give it a good brap. I have the air ride forks. Any tips on getting this bolt out?
    Also I cant post a lot of the time cause it keep saying spam, I cant post a picture of the fork taken apart
    PPS the oil filter below the large o ring is to small that come with it >:|
  14. DadsXJ650
    Alberta
  15. Franz
    I got mine out with an Allen key socket and a breaker bar. Where possible use your bike like a vice by slackening bolts with the part still on the bike.
    Timbox likes this.
  16. DadsXJ650
    Alberta
    I've got the hex socket and I've got a big breaker bar, normally the impact gun breaks bolts better, I think the guns like 250 or 350 lbs o_O. I am going to try and heat it some more and might put it in a board to help stiffen it and try my various methods. I was reading the factory or serivce might loctite this bolt, should I on the reinstall?
  17. Franz
    I just torqued my damper bolt to spec, l have a 900f. You can use Loctite if you want but the bolt cannot go anywhere and it should not slacken. My Haynes manual does not mention using Loctite on the damper bolt.
    If you do use thread locker use the blue stuff.
  18. DadsXJ650
    Alberta
    Sometime you got to be creative.
  19. DadsXJ650
    Alberta
    Hey Guys I've almost got it all buttoned up. The forks and everything seem straight but I would like to align my forks doing the bouncing thing, the video I found said I also need to undo the top center yoke? I thought I read somewhere else to do it you had the bottom loose ish, such as the ; axle, fender, axle pinch, the caliper swivel, and lower yoke pinches all loose. With the top yoke pinches tight lower from the stands/center stand, then bounce weight up and down on the front. Then tighten the lower yokes and everything else?
    I am getting pretty close to being ready to ride. Just dealing with getting it papered now:cool:
    Thanks again for the help!
  20. DadsXJ650
    Alberta
    Also can anyone tell me the brake line lengths and Bango size and angle for my xj650 LH
    I could take them out later and measure but would like to order asap. Check my brake line dates and they are bad.
    Would a 110cm brake line with 28 degree bangos work? I've seen other posts saying 30 or 35 degree
  21. DadsXJ650
    Alberta
    I plan on not using the junction
  22. DadsXJ650
    Alberta
    So I'm almost done but the bike is still leaking oil slowly from the filter housing. I thought my o ring was bad despite using the Fram ch6003 like suggested. On the second oil change i used the old o ring for the housing as it was beefier than the ones that came with the Fram filter. I don't think the housing is scuffed or anything seems smooth to me. Any suggestions
  23. JBurch
    Owego, NY
    Look for a crack
  24. DadsXJ650
    Alberta
    Hmm I did inspect the housing and case and didn't see a Crack on the second go, i will do a more thorough check later this week. If I find a Crack do I just start crying lol
  25. Dan Gardner
    Minneapolis, MN
    A replacement filter housing wouldn’t be hard to find. Or you could upgrade to the spin-on conversion.
  26. DadsXJ650
    Alberta
    Oil Leak seems to have stopped, it might have been residual after the last leak. I'll watch it close
    Well light at the end of the tunnel, bike would not idle proper or at all, took choke and starter fluid would still die down. Couldn't figure it out for a minute cause the only thing I changed was putting the fuel tank and the petcock back on, Fuel ran out the petcock on prime. So I ran fuel down my new line through a funnel instead of the gas tank/petcock. She purred. So do I need to rebuild my petcock? any easy way or do I got to order the rebuild or aftermarket?
    Jetfixer likes this.
  27. Franz
