dead cylinder
Discussion in 'XJ Technical Chat' started by davec, Dec 4, 2013.
  1. davec
    davec Member
    ontario canada
    rgr that,, we are gonna rent a comp tester..gunna make sure,, but at least its not a blown piston, (phew), its gotta be valve spring or stuck valve,,but if its a valve stuck,,how would we get a proper reading anyways?
  2. bigfitz52
    You won't. But then you'll have a better idea of what's going on.
    Based on the results of the first test, you might want to follow up with a "wet" compression test.
  3. Polock
    send your rental bill to Fitz
  4. TIMEtoRIDE
    You can actually SEE the valves thru the plug holes, if you look carefully.
    That would rule out the dropped valve, and the holed piston.
    But you could crank it - IGN off - by crossing the solenoid and HEAR the engine hit compression evenly, or - - 3 hits and a quicker spin.
    But seriously, get a real compression gauge.
  5. davec
    davec Member
    ontario canada
    its knocking. sprk to plug,, dead cylinder guys,,,thats all i know,,
  6. bigfitz52
    But that's all we know.
    I guess it depends on whether or not you're serious about figuring out what happened and what it might take to fix it. If you are then the first steps are dry and wet compression tests. Then you will probably need to pull the head. But if you just pull the head, you've missed the opportunity to get valuable information about the condition of the cylinders, including the good ones. Information that could prove to be very valuable in the upper-end rebuild decision making process. Figuring out exactly what broke will certainly influence the "repair vs. replace the motor" decision as well.
    Polock, the way most tool "rentals" work around here, you get 100% of your deposit back when you return the tool, so it is essentially free of charge.
  7. davec
    davec Member
    ontario canada
    my next post will be #s quite serious about fixing this and want to learn why,
  8. sektorgaz
    sektorgaz Member
    Western MA, United States
    Did you send the Fitz' check over?
