Diagnosing Charging Issue (I've tried it all)
Discussion in 'XJ Technical Chat' started by Will Beemer, Aug 28, 2025.
  1. Will Beemer
    Will Beemer New Member
    Manhattan Kansas
    I have a 1982 Yamaha XJ 550 that I bought as a flip. Currently, the bike will not charge itself. I've replaced the stator, the R/R, the battery, and the thing is still getting no charge. I've done all the different tests with a multimeter, including the resistance between the Green & blue wires, and nothing has gotten me to a conclusion. Between the white wires off the stator, I'm only seeing about .5 - 1.6 volts AC (depending on rpm), where I believe I'm supposed to see about 60 volts.
    Important note: When I first replaced the battery on the bike, there was a mix-up and the leads were on the wrong poles (I know this is incredibly stupid). I'm assuming this messed something up that I'm not seeing but from what I can, all the wiring seems okay as far as continuity goes.
    Please help me I want to drive this thing off a bridge.
  2. Rooster53
    So that means no excitation to the field coil (rotor), so no voltage induced in the stator when the engine is running
    Try reading this thread and maybe get some ideas - the key takeaway for field coil excitation is the green (control wire) should be near zero volts with key on and bike not running.
    https://www.xjbikes.com/forums/threads/xj750-seca-charging-issues.132995/#post-688996
    Timbox likes this.
