Dot 3 Vs Dot 4 Brake Fluid
Discussion in 'Hangout Lounge' started by Alive, Jul 25, 2008.
  1. Alive
    Alive Active Member
    Queensland, Australia
    Anyone know what the difference is?
    Cheers
  2. chacal
  3. Alive
    Alive Active Member
    Ooookkkkk well that explains a lot... cheers
  4. bigfitz52
    If I read that correctly, DOT3 and DOT4 are pretty much the same...although I was always under the (possibly mistaken) impression that DOT4 was "LMA" (low moisture acquisition.) There was a time (some years back, admittedly) when DOT4 was difficult to find, being only for high performance vehicles. The Lockheed brake on my Norton calls for DOT4, I have an OLD can of CASTROL GT-LMA brake fluid, DOT4. (I saved it for posterity, I use fresh stuff of course.) If the article is to be believed, it appears as though 3 and 4 have evolved into much the same thing. I'm skeptical, will continue to use DOT4.
  5. Alive
    Alive Active Member
    Reason I asked is because my reservoir says to use Dot 3 and I bought a bottle of DOT 4 then thought I wonder if it will make any difference.
    In this case I think not :)
    Cheers
  6. coldndead
    coldndead New Member
    prescott valley , az
    chacal, thx for that link. i tend to enjoy obscure knowledge so that was a nice start for the day. as a new-b to the site i was especially happy to find a good source for parts! the two local dealers (one is a yamaha) suck. i think i'll just the change brake fluid with good o'le DOT 3.
    thx again :D ... cnd
  7. Gamuru
    Gamuru Guest
    Granite Falls, WA
    I get asked this question a lot. The simple answer is that DOT 4 has a higher boiling point than DOT 3 and, therefore, recommended where severe driving conditions are present.
    BTW, good article!
  8. bigfitz52
    Yeah, you're sure not gonna hurt anything running DOT4.
  9. Brtino
    Brtino New Member
    Colorado Springs, CO
    Chacal - man you are a great source for information.
