Drive by with the Emgo Turnouts
Discussion in 'Hangout Lounge' started by RJ C, Sep 16, 2019.
  1. RJ C
    RJ C Member
    MN
    I didn’t want to spend a ton of money on my bike but I wanted to give these a try...
    :eek:
    Louder than stock I wanna say.
    She's running lean too. Best fix that before you hole a piston.
  3. RJ C
    RJ C Member
    MN
    Was thinking the same thing.
  4. RJ C
    RJ C Member
    MN
    Pulled the plugs...4 looks rich? 1-3 lean? I noticed that #4 manifold pipe is not as hot as the other 3.
    You all know more than I do, suggestions are always welcome. Probably going to tear down the carbs over the next couple weeks. These are the plugs that were in the bike since before I took the carbs to church. Maybe just replace em and see how the new ones look after a ride?
  5. kerriskandiesinc
    NY
    Those don't look terrible......except No 1 is wet......spark??
    RJ C likes this.
  6. k-moe
    Put in new plugs to check.
    Going by the ground straps (insulator color isn't as important) #1 is lean. #2 is slightly lean. #3 is good. #4 is wet and rich.
    Keep in mind that's only a rough look since the plugs aren't new.
    It's #4 that's wet.
    RJ C and kerriskandiesinc like this.
