dynatek coil trouble
Discussion in 'XJ Technical Chat' started by bruceridesthestyrker, Jun 15, 2019.
  1. bruceridesthestyrker
    bruceridesthestyrker New Member
    galveston texas
    3 Ohms +/- 10
    Manufacturer Part Number:
    2FM-46-15050x2 / DC1-1x2 after reading thru. what to make my 37 year old xj750 maxim a better bike. i have been doing things as i can afford. i ran across changing the coils with these coils for better spark and i dropped the coins and installed them. i also bought preassembled wires with caps and the coil bracket from a member n this web site. after i finished the bike ran great. not any better or worse than before but it was running great. fast foreward to a week or 2 riding about 100 miles total and the bike started having a misfire at idle. i could get past 2000 rpm it would run ok but anything lower it would misfire and seem like it dropped a cylinder, i rechecked all the connections and even put my old caps on the new coils. i tried new plugs no difference. i put my old coils on the bike and it runs great. i tried to swap out the new coils one at a time but the bike doesnt like the new coils. any ideals?
    if you got them from Chacal www.xj4ever.com contact him he stands behind his product
    also check out your charging/battery voltage if that goes low at idle it can cause issues you described.
  3. chacal
    The cheap Chinese versions of the real Dyna brand coils are not up to the same standards, and we've heard of multiple instances of this problem (which is the reason we don't offer them!).
    Also, the ohm rating of 3 +/- 10 ohms can't be right!
    Franz and XJ550H like this.
  4. XJ550H
    is there a way to tell the difference between the china version and the Dyna coil that you sell Chacal?
  5. k-moe
    For a start, the part number the OP provided is not a Dynatek part number.
  6. mlew
    mlew Well-Known Member
    Apex, NC
    Ohm the coils to see if they are in spec. If they are not send them back for a refund and get genuine Dyna coils. I have had a set on my bike for many years with no problems.
  7. bruceridesthestyrker
    galveston texas
    i looked at the item i purchased on ebay and it says dynatek style ignition coils so your correct it is a copy from taiwan i have been duped.
  8. k-moe
    What's really surprising is that the ads for them claim Taiwan origin. Taiwanese manufacturing is as-good-as (or nearly so) Japanese, though there are exceptions.
    These clearly fall into the exception category.
  9. XJ550H
    honda 750 coils are supposed to be a good choice
  10. Jetfixer
    Plus 1 , been running these for going on 3 years now with no issues and Cycle Recycle part 2 sells these as new fit Honda,Kawasaki,Yamaha 39$ ea they also sell plug wires a.d caps. These coils are Hiatchi and fit in place as same location as stock coils.
  11. XJ550H
    are the plug caps resistor types? I see the ad and the second ad with wires and caps.
    http://www.newmotorcycleparts.net/electrical/coils.html
  12. bruceridesthestyrker
    galveston texas
    my stock coils are fine. i just read the dynatek coils produced a hotter spark. i had fouled a spark plug and it just seemed to me the new coils would be a improvement plus the red spark plug wires look cool. i am sending the coils back i paid $95.00 i found some real dynotek coils for $125.
  13. Jetfixer
  14. Jetfixer
    My 71VW I swapped to an 009 Bosch distributor and compufire electronic ignition , this still uses a coil , I fell for it I bought a shiny chrome coil ...and there was no difference between the stock coil and the chrome coil till it leaked oil. So I'm running the stock coil with no problem...a hotter coil might help if you have high oil consumption , and face it WE all fall for the hype with buzz words "high performance" pretty shiny things.
  15. k-moe
    Coils won't solve plug fouling. They will help you to get by for a while if the fouling is caused by oil though.
    The most common cause for excess oil getting into the combustion chamber is hardened or cracked valve guide seals.
  16. bruceridesthestyrker
    galveston texas
    My bike has no oil usage no smoke at startup or while running. The plugs are tan and the motor has 23000 miles on it. I noticed today my head gasket is seeping on the left side toward the front if it gets worse off comes my head I want a seca 750 exhaust cam and a big bore kit while I have it apart
  17. XJ550H
    is there a difference between maxim and seca exhaust cams in the 750?
  18. k-moe
    1. The leak is more likely coming from the valve cover. Generally leaks at the inner part of the "H" weep down to the head gasket and make it look like the head gasket is leaking.
    Clean, degrease, dust with talc, and look for the source before tearing into the engine.
    A leaky head gasket will more often announce itself with a whistle than with oil. There are very few places where oil comes near the head gasket. Right in the center were the cam chain tunnel is (sealed with a seperate gasket), and on the right side where the oil feed and return are (sealed with o-rings). Both areas have a seal seperate from the head gasket, which is why an oil leak from the head gasket is so unlikely.
    2. The Seca 750 and Maxim 750 cams are the same.
    3. The big bore kits are not a good value IMO. The cylinder liners are on the thin side, and you get very little gain over the stock displacement. The plus side is the relative ease of sourcing a kit, versus finding an XJ900 engine to swap in.
    Scott I likes this.
  19. LarryMc
    LarryMc Active Member
    Lakewood, WA
    You'll be happy with your REAL Dyna coils.
  20. bruceridesthestyrker
    galveston texas
    I wouldn't change my head gasket if it was weeping. I think it most likely is the valve cover gasket like you stated it needs cleaned to be sure. I thought the seca had a different exhaust cam that's why it ran a faster quarter mile time. I like my bike how it is I had thought about a big bore but its Chinese junk for the most part.i keep the bike inside and its clean for its age
  21. k-moe
    The Seca 750 ran a faster 1/4 mile time for two reasons.
    1. The fairing.
    2. Pee Wee Gleason.
    And #2 had a bigger role to play IMO.
    The Maxim 750 is supposed to have a different output gear ratio, but I'm not sure that isn't a misprint.
    bruceridesthestyrker likes this.
  22. XJ550H
    seca has different diameter wheel taller rear tire.
  23. k-moe
    Yes, but not enough to account for the 1/4 mile time. Not by as much as is listed anyway.
  24. XJ550H
    possibly something in the transmission I looked at the gears same. possibly something in the other tranny parts. 480 pounds vs maxims 520 pounds could help too
  25. bruceridesthestyrker
    galveston texas
    I remember when pee wee Gleason ran 11.99 on the seca 750 I think it was the first stock production. 750 to break In the 11 second quarter mile time. I never ran across a Yamaha seca in my younger days to race. I can tell you i beat a Honda 650 night hawk bad. I beat a Kawasaki csr650 bad and i beat a Honda 750 from a dead stop with 2 of us on my maxim 750 in 1985
    Jetfixer and k-moe like this.
  26. k-moe
    Yes, it was the first to break that record. Yamaha held it for about a month, then Kawasaki released the GPZ750. 11.93 @ 109 MPH.
  27. bruceridesthestyrker
    galveston texas
    my fuel gauge decided it wanted to act stupid. it has been working perfectly but yesterday i noticed it said that i was out of fuel. i filled the bike up and no it stays mostly between 1 and 2 bars. sometimes it will show a full tank. i am guessing the sender is going bad, are there aftermarket senders? or can the OEM sender be fixed or swapped out with one from a different model bike? i also received a refund from the guy who sold me the fake dynatek coils. now i can order the real dynatek coils.
    Chitwood likes this.
  28. k-moe
    Most of the time the sender has a bit of rust on it, ot the pivot is sticky.
    You will need to pull it to inspect, and you will need a new gasket.
    First thing to check is that the plug is firmly seated in the receptacle, and the insulation is not worn through, and that the crimps on the harness pins are in good shape. Do that at the plug under the seat for the sending unit, and the wiring to the display.
