Electric issues
Discussion in 'XJ Technical Chat' started by Jburton, Jun 6, 2017.
  1. Jburton
    Jburton New Member
    Wisconsin
    Hey everyone,
    Recently out for a ride on my 81 xj750, i was cruising along, and instantly all electronics shut off, i pulled over and upon further inspection with the key in on position, no electronics on the bike work, i just installed a brand new starter relay, but it could still be faulty, checked all connections at headlight bucket and towards the rear and all are good. Any suggestions on where to search next or how to test the relay???
  2. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    Welcome to the group,
    Have you cleaned and tightened all ground connections?
    What prompted the starter relay change, was there previous electrical issues?
  3. Toomanybikes
    Tsawwassen bc
    Fuse box? Or ignition switch contacts
  4. Jburton
    Jburton New Member
    Wisconsin
    All contacts are good, fuses are good. Starter relay was getting stuck on, and continuously running the starter. I only know of one ground, right too the motor off of the battery.
    Any help is greatly appreciated, as my bike is sitting in a random driveway until fixed.
  5. XJ550H
    this would be a seca 750?
    grounds at ignition coils ,ground to frame from motor.
    how is your oil level low oil can trigger the solinoid.
    check the connector from solinoid/battery to main. fuse red wire single connector.
    do you have 12 volts at the main fuse?
  6. Jetfixer
    Just a thought is your battery low on charge? a bad battery can cause several issues?
    Stumplifter likes this.
  7. Stumplifter
    near Irma, WI
    Well your bike is NOT in my random driveway . . . where in Wisconsin are you?
    If the old starter relay was getting stuck on it may have damaged the battery, get a multi meter on it and see what voltage you have.
  8. Polock
    did you bump the kill switch?
    XJ550H likes this.
  9. Jburton
    Jburton New Member
    Wisconsin
    Yes it is a seca750, i am near appleton wi. Battery is a brand new agm from batteries plus, kill switch is fine, ill habe to recheck mpre grounds. Also just did an oil change 2 weeks ago. Im going back today. I did not have a multi meter yesterdag.
  10. Jburton
    Jburton New Member
    Wisconsin
    Habing problems with my xj750, anyone know how to properly test a starter relay/solenoid
  11. jsngrimm
    jsngrimm Member
    Akron,Ohio
    There are a couple ways you can test them, most simple is tapping it with the handle of a screwdriver/mallet while trying to start the bike, it may just be stuck. Better way would be remove it from the bike and check the coil with a multimeter, if the coil is good then connect only the power to it, and while you try to start the bike check the other contacts with a meter to make sure they are closing
  12. Jburton
    Jburton New Member
    Wisconsin
  13. k-moe
    Merging this into your existing thread.
  14. k-moe
    Now we can ge back to this.
    Does it still have the original fusebox?
    Here is why I ask.
    Your Fuse Box -- A Ticking Bomb??? By: Rick Massey
    You have multiple electrical issues, and the fusebox is one of the few parts that they all have in common.
    The fuses can be good, but the fusebox (specifically the fuse clips) still be at fault.
