Ever wonder about the intake boots?
Discussion in 'XJ Technical Chat' started by hogfiddles, Aug 12, 2018.
  1. hogfiddles
    Here's a quick peek at a cross-section of xj650 boots. It's amazing how thick they really are.
    From the front
    Cross-section
    I have some from either a 700X, or a 900rk ( on the shelf somewhere...I don't remember which at the moment---) and i will take post those here later. They have a metal liner.
    Toomanybikes likes this.
  2. Minimutly
    Minimutly Well-Known Member
    West Wales, uk
    Well made, that's for sure, and consider how long they last. The ones on my Kawasaki are also very good.
  3. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    It would be interesting to compare the knockoff versions of the boots to this.
    hogfiddles likes this.
  4. Toomanybikes
    Tsawwassen bc
    Have found that most of the boots with cracks on the outside and almost never go all the way through, but leaks occur at the gasket and mating surface has cracked, which can be cured with rtv.
    bminis01 likes this.
  5. wkxj
    wkxj Member
    nm
    That's good to know! The ones on my 550 are looking a little rough.
  6. hogfiddles
    If somebody has an extra one of the knock off ones to send to me, I'll do it....
  7. chacal
    I don't, they were all sent back to their maker.........
    hogfiddles and jayrodoh like this.
  8. Taylo105
    Taylo105 Active Member
    San Diego CA
    I think I have some knock off works in the old parts bin.... let me see if I can dig them out
  9. Tim O
    Tim O Active Member
    Charlottesville, VA
    I know you guys said not to but I couldn't resist... I've been running the knockoffs for almost a year with zero problems.
    That said, I still have my old ones handy to coat and put back on once these start failing...
  10. hogfiddles
    That's fine. If they hold up for you, that's awesome, too.
  11. MattiThundrrr
    My reason for this is that there have been some reports of boots collapsing under vacuum, or layers coming off and blocking intake. I wanted to compare thickness and quality of the materials. Not saying that the other ones don't work, I simply want to see any differences.
  12. k-moe
    They look identical. The thickess is the same. I've had mine on for a bit over 10,000 miles and they are perfectly fine so far. I think the delamination troubles may have been down to a poorly made batch. I can probalby take pics when I have the head back off to fix my mistake. I'm not sure how long it will be until I can get to that job though.
  13. MattiThundrrr
    Thanks for the info...
  14. Colin 85 700
    Colin 85 700 Active Member
    Thunder Bay, ON
    If your boots are starting to crack, a light coat of grease or petroleum jelly will keep them from getting horribly worse and save em for a while, not a fix, but will lengthen life.
