Everything *BUT* the Headlight works
Discussion in 'XJ Technical Chat' started by Joe550, May 1, 2026.
  1. Joe550
    Joe550 New Member
    BC
    Any suggestions where to start? I've swapped the bulb for a new one and it still doesn't come on, high or low. Gonna check the fusebox tonight and update if that's all it is
  2. cds1984
    cds1984 Well-Known Member
    Perth, Western Australia
    Multimeter will help greatly. If it's not just a fuse.
    Negative on the engine and positive lead poking the connectors, type of thing.
    I've had a melted headlight connector, broken female spade connectors, corroded through wires at connectors.
    On and on. Multimeter and tugging on wires to see if they stretch as the copper is corroded away and it's only attached with the insulation, haha no seriously. Hopefully it's just a fuse,
    Timbox likes this.
  3. Joe550
    Joe550 New Member
    BC
    There is no burned fuse
    Oh no
  4. Joe550
    Joe550 New Member
    BC
    Okay after a look at a wiring diagram it seems my flasher cancel relay? Is missing. Which is very strange that the headlights don't work but everything else does, when the headlight relay is there and seems fine.
  5. Timbox
    I would guess that once you get a multi meter and start to trace the power going to the headlight, you will find the issue. Could be at the left bar switch? Sometimes the wires come off the factory solder pads. You will have to get some test equipment if you want to troubleshoot these issues.
    cds1984 likes this.
  6. Dan Gardner
    Minneapolis, MN
    You don't need to spend a whole lot of money on a multimeter - for what you need, you don't need to spend more than $20 USD - not sure what that would be in Moose Bucks.
    Worth the investment.
  7. Joe550
    Joe550 New Member
    BC
    Got in there with a multimeter and did a continuity test. Found that the headlight plug goes to the *missing* flasher cancel relay, and everything else is there and seems to work fine. So that relay is in the mail now
  8. Joe550
    Joe550 New Member
    BC
    Relay showed up. Has 6 wires instead of the 5 going to this plug *and* they don't line up with how the existing plug is wired. Hooray
