Exhaust collector question
Discussion in 'XJ Technical Chat' started by NikoRx, Jul 29, 2024.
  1. NikoRx
    NikoRx Active Member
    Columbus, Ohio
    IMG_3983.jpeg Looking for advice on how to fix or replace this, or can I keep on and ignore it?
  2. cds1984
    cds1984 Well-Known Member
    Perth, Western Australia
    Oxy/acetylene, an old computer case, Tin snips, some galv paint and your good to go.
    Patch it in other words.
    Timbox, NikoRx and Franz like this.
  3. Dave in Ireland
    Ireland
    Exactly, and people toss out valuable repair sheets every week in every neighbourhood. Old fridges, washing machines, tumble driers, etc.
    cds1984 and NikoRx like this.
  4. NikoRx
    Columbus, Ohio
    I do not have access to welding equipment. Is it possible to rent or buy for an affordable price? I want to assume JB weld would be a poor option?
  5. Roast644
    Roast644 Well-Known Member
    WASHINGTON
    JB Weld is an option! I did a small muffler patch with it recently. Cut a small metal scrap out of your dishwasher or computer case that is slightly larger than your hole and thread it in from the outside. I welded a nail on mine to pull it back, but without a welder a small screw could do the same thing. Smear the JB weld around the edges after the piece is inside, pull it back and secure (rubber bands, weights, baling wire...whatever it takes) and smear some more JB over the outside. You can snip the screw off later.
    Normal JB weld is rated at 550 degrees. Don't get hung up on making it perfect. You are starting with scrap. A mistake or two isn't going to matter.
    NikoRx likes this.
  6. NikoRx
    Columbus, Ohio
    that is super helpful, thanks for the details, I may try that first and if I run into issues I can try to find a welder
  7. NikoRx
    Columbus, Ohio
    My fiancé has zinc plates sheet metal, would that be an ideal patch?
  8. cds1984
    Even better. It'll last longer than the original metal, which was pretty long already.
    I ended up pretty much encapsulating the whole collector when I fixed mine up.
  9. Timbox
    If and when you go to use the treated metal, make sure you have very good ventilation or even a fan blowing the air away from you. That stuff is great to use, but our bodies do not like that stuff.
  10. NikoRx
    Columbus, Ohio
    Is that if I weld it or does that include the JB weld method mentioned earlier, or both haha
  11. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    Welding plated metal (zinc) makes noxious fumes. No worries with JB Weld.
    Timbox likes this.
  12. cds1984
    Just wait... In a few years we will all die from the 'noxious' fumes from jbweld.
    But in the meantime I agree, completely.
  13. Huntchuks
    East Rochester, NY
    Is JB Weld known to cause cancer in California??
    biggs500 likes this.
  14. cds1984
    Sorry.
    Drunken melancholy on my part.
    I really shouldn't spew my thoughts out at this point.
    A fragile existence we perceive.
    My apologies.
  15. Huntchuks
    East Rochester, NY
    My post was a joke. Everything here in the States has a warning that something about it is known to cause cancer in California.
  16. cds1984
    I got your joke and felt a pang of remorse for posting at the same time haha.
    Living is bad for your health - endorsed by your local government.
    NikoRx likes this.
  17. Timbox
    With how thin the collector is from the rusting process, I am not too sure how well either process will work for any longevity. I do wish you luck if you try to repair it. I would think getting a used one online would be best.
  18. cds1984
    This is what mine started out like. I cut it open to pull out the rattling rusted out baffles.
    You are right about thin.
    By the time I finished adding steel it was more computer case than original.
    Worked though.
    Franz likes this.
  19. Roast644
    WASHINGTON
    Exhaust by Hewlett Packard... :D
  20. Dave in Ireland
    Ireland
    Freash Air causes cancer in Californiay.
    It's like the kind of thing I'd never heard before
    Living the high life but let me warn ya
    It's sore, oh man, it's sore.
  21. Dave in Ireland
    Ireland
    Hopefully not Packard Bell, it will only last a month.
    cds1984, Oblivion and Roast644 like this.
  22. chacal
    Those baffles are really the secret to success for the collector....they maintain the correct "pulsing" relationship for the exhaust flow(s) and create the scavenging effect within the exhaust system that is so near and dear to all of our hearts.
    All of life can best be explained as "electrons looking for a place to rest".
    cds1984 and Franz like this.
  23. NikoRx
    Columbus, Ohio
    Found this beauty of scrap on an old oven while walking the dogs!
    cds1984, Dave in Ireland and Roast644 like this.
  24. NikoRx
    Columbus, Ohio
    Picked it up from the welder today!
    Dave in Ireland likes this.
