exhaust swap
Discussion in 'XJ DIY How-To Instructions' started by Nic, Oct 15, 2017.
  1. Nic
    Nic Member
    Philadelphia
    Trying to put the 750 maxim exhaust pipes on the 650 anyone done this before I am having problems with the kickstand and the rear mounts.
  2. hogfiddles
    750 exhaust pipes are a bit longer/taller, and the 650 maxim pipes do not go to a collector box..... The mufflers are both 2 -into-1 single-piece units with a cross-over pipe.
    Sort of like trying to put an xj550 engine onto a chainsaw.......the exhaust is totally different
  3. Nic
    Nic Member
    Philadelphia
    Are you saying it's not going to work?
  4. hogfiddles
    I'm sure some has probably done it somehow, but the 750 collector box is:
    1. going to hang lower
    2. Probably still going to interfere
    3. Muffler mounting points still not line up.
    I think you're going to need to remove the center stand
    AND
    I'm not sure that there is even provision for the collector box rear mount to bolt on.
