Failed coils? Probably not, but...
Discussion in 'XJ Technical Chat' started by DoubleTigerLefty, May 9, 2017.
  1. DoubleTigerLefty
    DoubleTigerLefty Member
    coquitlam
    ...open resistance on both HT leads to the coils
    -chopped a bit of the insulation back on the HT leads, multimeter reads open. MMeter Functioning perfectly
    reading closed cuircuit directly between pickup coils
    BUT
    -zero readings between pickup wires at TCI
    - will do more thurough examination of wires (which run along the base of the bike, and disappear in between components
    ---HOWEVER---
    I do get sparks (albeit weak) when I pull them out and ground them to the engine case, and hit 'start'
    BATTERY is @ 12.51, will charge for tomorrow
    ^^disclaimer^^^
    1. PO's genius (aka my younger self's genius) makeshift "electrical pan" most likely held water during the winter. Stored outside and neglected while I was taken out of town on emergency. Long story, please resrve judgement
    2. Tank sealant was all over the plugs when I took them out, another side effect of the failed tank sealant which resulted in me having to shell out hard-earned cash for new carb bodies, new fuel tank, degreasers and chemicals and petcock. So new plugs will be bought anyways.
    3. Got rid of starter cirucit cutoff relay. Bike turns over fine, still doesn't fire.
    Please leave any comments you may have as to what this strange lack of resistance could be the result of (specifically; I understand it was out in the rain, unfortunately can't do anything about that except not repeat it.) and why i seem to have )weak( spark regardless of lack of resistance, and what the next thing you would do.
    I will report tomorrow with results of further quests through this month-long journey through my ignition system.
    Much love.
  2. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    The oozing tank sealant, sounds like The Blob.
    Was this an etching to adhere sealant? How bad do the rubber bits that were exposed to it look?
  3. XJ550H
    are you testing from spark plug lead to spark plug lead?
  4. Toomanybikes
    Tsawwassen bc
    I do have spare coils and such for your bike. saw that bike in the Pic on Craigslist about a year ago, always wondered who got it
    I'm out in Tsawwassen
  5. DoubleTigerLefty
    coquitlam
    Awesome to know, thanks, toomany. I put. A lot of love into her since, but this einter was a cataclysm for me and the bike, but she's just about perfect. Soon as i get sparks back to bright and blue...
    I was testing the same HT circuit, lead to lead. Open resistance, but it says in the manual to look elsewhere if such a problem arises... resistance is resistance, though, so i dunno... will report back asap
  6. Toomanybikes
    Tsawwassen bc
    Have you done this on muti meter?
    I have done it , oops and wonder why no readings
  7. DoubleTigerLefty
    coquitlam
    No, mine is simpler, with only two plugs. After work today, ill be doing a few tests which the mechanics at my work suggested.
  8. DoubleTigerLefty
    coquitlam
    Okay, so the tests returned the following results:
    Pickup coils @ tci are in spec.
    Secondary windings are 11.9 and 11.6 - This is WITHOUT the caps, multimeter shoved right up into the wiring.
    Primary windings are BOTH 2.9
    So... if I'm correct, BOTH primary windings are out... The owner of the shop i went to said he'd been doing bikes for 51 years, and said he'd never seen both coils fail on a bike before... But what am I to tell him? The multimeter doesn't lie, does it? To tell the story of my ignition system is a long one... I've experienced a few shorts in the ignition system, blown fuse a few times, and arc'd a few times due to stupidity, from the metal positive connector for the solenoid to the frame. My hand is much steadier now..
    Has anyone else seen both coils fail before? I am going to order fresh, brand new ones if nobody stops me.
    Thanks!
  9. Jetfixer
    I run Honda CB750 coils these have replacable plug wires they mount in same location as stock. Can still be bought new 39 each from Cycle Recycle part 2 they also sell wires and caps. So I take bike will not start? What condition are your coils in? Are there any cracks in the case?
  10. XJ550H
    did you ohm out the sparkplug caps?
  11. DoubleTigerLefty
    coquitlam
    They look great! I've deduced why they may have failed. In testing for the spark, I may have not kept the plug grounded when i took it out of the head. So I suppose that may have been a p;roblem for the primairy windings, not giving them anywhere to go, and it may have happened just too many times. So now my coils are 2.9 - 3.
    As for the caps, they're all 4.9, I've rep;laced the stock ones with NGK's.
    However, when i measure at the caps when they're still connected, I get something like 21.9 on the secondaries if I recall correctly. I am getting coils either off fleabay or off a gracious member who lives near enough to me. And then I'm buying that lottery ticket so I can buy you all beer for help;ing me with my moronic past self's mistakes.
  12. May_J_Aaron
    May_J_Aaron Josh May
    Chandler, Arizona
    Is there a specific year or model of CB750 that would match?
    I have an 83 Maxim 750.
  13. XJ550H
    May_J_Aaron likes this.
  14. Jetfixer
    The 81 to 83 ...cycle recycle part 2 sells these coils new they also carry wires and caps ..the coils are like 39$ each last I looked ...there place looks like a strong wind would blow it down ...but it is floor to ceiling with old bike parts .
  15. May_J_Aaron
    Chandler, Arizona
    So I get about 3.1 OHMS at the pigtail when testing it which is good but when testing the wire, positive in the cap making metal to metal contact, negative in the pigtail with the voltmeter set to 20k I don’t get any reading...
    Is there a different way of doing it?
    obviously I don’t test it 1 handed but just to show how I’m doing it.
    I’m also aware that left coil is 1 & 4, right is 2&3.
    Am I doing this right? It’s what I saw on YouTube...
  16. Rooster53
    You need to check the ignition coil secondaries by measuring from cap to cap. Set the meter to 200K if the caps are on as the expected reading will exceed 20K when adding the 5K for each cap. You can use the 20K scale if you remove the caps as the reading should be about 11k ohms.
    https://www.xjbikes.com/forums/threads/the-information-overload-hour.27544/
    For all XJ models except XJ700, XJ750-X, and XJ900 models:
    Primary (input from TCI): 2.5 ohms +/- 10%
    = 2.25 ohms - 2.75 ohms acceptable range
    Secondary (output to spark plugs): 11K ohms +/- 20%
    = 8,800 ohms - 13,200 ohms acceptable range
    5K +/- 20% = 4,000 to 6,000 ohms per cap acceptable range:
    all XJ650 models
    1985 XJ700 air-cooled models
    all 1981-84 XJ750 (except XJ750RL) models
    all 1983-84 XJ900RK and RL models
    all XJ1100 models
    all XS1100 models
  17. Polock
  18. XJ550H
  19. May_J_Aaron
    Chandler, Arizona
    It’s worth paying a little extra to know it’ll work!
    Looks like it would allow the plug wires to be changeable as well which is nice!
  20. XJ550H
    dynatek coils are not direct bolt ons you will have to make an adaptor or buy it from xj4ever
  21. Jetfixer
    That is what is nice with the CB750 coils they bolt right in stock location ,and is less than Dyna coils .
  22. May_J_Aaron
    Chandler, Arizona
    So the 4 inch bolt distance is the same... but there’s no specs... I may have to give them a call.
    Ones looks like a whole package but it’s for earlier years of the CB750 and the other is just coils.
    D93BC4B4-2A44-4795-8FA2-68C71D719A00.png 7A6ADDB2-5C60-489C-B9CC-82D4BDD56F12.png
  23. Jetfixer
    The one for 39$ is the one you want you have to " flip" it over to clear the tank ..the plus wires close to the frame in other words. I dont recall the ohm reading...and did not worry about it these coils work great and trust me when I say it can knock you on your a$& ...:rolleyes: ...I have buried the speedo several times and still had throttle with no issue .
