Fast blink issue
Discussion in 'XJ Technical Chat' started by Cattleman XJ, Dec 4, 2019.
  1. Cattleman XJ
    Cattleman XJ Member
    Texas
    Right side works fine. Normal rate, and front/rear/dash indicator blink in unison.
    Entire left side blinks rapidly, and the front blinks in opposite time with the rear and dash indicator, which fire together correctly.
    Thoughts?
  2. raskal
    raskal Active Member
    Abbotsford B.C. Canada
    do the types of bulbs in the right side match the left side?
    I'm thinking a wrong wattage bulb?
  3. Toomanybikes
    Tsawwassen bc
    Or a pinched hot wire to one of the lights. Doesn’t blow the fuse so it flashes fast
  4. jayrodoh
    jayrodoh YimYam
    Cleveland
    Sounds like a bad ground to me.
    Rooster53 likes this.
  5. Rooster53
    ^^^ that - and you should also see an issue with the front running light as in the indicator and rear flasher illuminated dimly with no flasher command.
  6. Polock
    can't wrap my head around this
  7. Rooster53
    With a missing ground on the front assembly (wire, bulb, bulb socket, mounting) the running light will illuminate using a path to ground through the other bulbs. When the flasher applies 12V to the circuit, the running light goes out because of the 12V on both sides of the filaments, which gives the impression of flashing out of sync.
  8. Cattleman XJ
    Cattleman XJ Member
    Texas
    That sounds like as good of an explanation as anything. I’ll start poking around on it
