female built 82 xj650 (still a work in progress)
Discussion in 'Hangout Lounge' started by Heather B, Aug 8, 2019.
  1. Heather B
    Heather B New Member
    Nebraska
    0525191319_HDR.jpg 0525191448.jpg 0624191722.jpg 0624191829.jpg 0716190045a.jpg 0716190045.jpg 0717191932_HDR.jpg 0719190943.jpg 0719190210.jpg 0718191838.jpg 0719191841.jpg 0525191319_HDR.jpg 0525191448.jpg 0624191722.jpg 0624191829.jpg 0716190045a.jpg 0716190045.jpg 0717191932_HDR.jpg 0719190943.jpg 0719190210.jpg 0718191838.jpg 0719191841.jpg 0808191409_HDR.jpg 0808191409.jpg 0808191409~2.jpg
    Franz and Timbox like this.
  2. Timbox
    Nice, looks good.
    Heather B likes this.
  3. dkavanagh
    Rochester, NY
  4. Polock
    i doubt that paint is going to last very long on the tires but it looks like you did a nice job
    plug the frame where it's cut, don't want water getting in there
  5. Heather B
    Nebraska
    I
  6. Heather B
    Nebraska
    I agree with you on the wheels tho it is holding up fairly well so far. I found YouTube videos showing people using vinyl spray paint to make whitewalls. I had to try it at least once. The entire bike is still in mock up faze. I'm just trying a few things to see what I like and don't like, and what custom parts I need to find or make. This is my first xj build and is my last bike build.
  7. Heather B
    Nebraska
    This was the last bike I built. 81 SP500 junkyard find received_371379850204047.jpeg received_579375395927833.jpeg
  8. Polock
    that looks good too. but take care of the open frame tubes, if water gets in there the next stop is the swingarm bearings, not good. there's a weep hole down there that should be open but if it isn't water can get in the lower frame tube and gets trapped, then the side stands falls off. squirt some oil in that lower frame tube.
    i think a 12ga shotgun shell fits the frame tube
  9. chacal
    This is a premier example of the expertise that is only available on the xjbikes.com website.
  10. cgutz
    cgutz Well-Known Member
    SE South Dakota
    I used white sharpie paint to white letter tires. So far they have held up 5 seasons, with just an occasional retouching. Of course, your area of paint coverage is a lot larger.
    Nice project.
  11. k-moe
    And if you drill out the primer pocket you can hot-glue a large LED into it.
    chacal likes this.
  12. XJ550H
    .you can put leds in where the primer goes
  13. k-moe
    Nope. The leads go into the front bit, what for the shooting and all.
  14. Bluegray57
    Bluegray57 Active Member
    US
    This is the first single seat conversion that looks good to me. Is it off the shelf or did you make it yourself. Are you adding a pillion or will it be left as is?
  15. XJ550H
    yes it is a very nice seat I like the dead blow hammer too
  16. Heather B
    Nebraska
    The seat is from a stock HD that I picked up from a pawn shop for $100. I had to remove the seat pan and torch the plastic to mold around the frame and get it to sit down low. I'm thinking about modifying a 10in rear fender to cover over the the cut tubes that are currently plugged with rubber and mate up with the back of the seat. The seat is held firmly in place using costume brackets attached to the rear shock mounts. The front of the seat is not mounted and is not really needed... At least for now. The seat is very sold and comfortable the way it is. Next year I'll make a costume seat pan to replace the current modified HD pan. Im just waiting to find and install the right rear fender first.
    XJ550H likes this.
  17. Heather B
    Nebraska
    Currently I have rubber plugs covering the opening of the tubes. I'd like to cut those back a little further, put a modified 10in wide rear fender over top of the rails and weld everything closed. For now it's water tight temporarily.
  18. Heather B
    Nebraska
    P
    I Painted the tires only to help me get what was in my head out in the open where a can see it in real life without spending a bunch of money. I used a Dremel to sand off the glossy coating on the tires and then wiped them down really good with gasoline. Then I painted them. So far it's holding up and it's helped me to see the rest of the bike as I'm designing it. At the end of this build I will be stripping the paint back off and will be using a product call Mr. Whitewalls.
