First bike/ First build xj750 maxim cafe build.
Discussion in 'XJ Modifications' started by Goldenr, Jan 16, 2024.
  1. Goldenr
    Goldenr New Member
    Phoenix, AZ
    Long time lurker here. First post.
    Picked this bike up a year a half ago and tore it down. Teaching myself new things as I went. Picked up a Seca tank and made some side covers for it from fiberglass.
    IMG_20231231_185350_212.jpg IMG20240114133912.jpg IMG_20220729_154112.jpg IMG_20221010_011311__01.jpg IMG_20221226_210405.jpg
  2. chacal
    Wow, that is sharp looking, can barely tell it was an XJ750 Maxim in it's "previous life". Nice work, and welcome to The Club.........
    Goldenr and Roast644 like this.
  3. Roast644
    Roast644 Well-Known Member
    WASHINGTON
    That's super clean! Did you mount a small battery under the seat? What sort of speedo did you use?
    Goldenr likes this.
  4. Melnic
    Melnic Active Member
    Nice bike and clean.
    Tell us more about the following.
    Mufflers you put on.
    Velocity stack/filters on intake of carbs.
    Re jetting the carbs? what did you move from and to and how did you go about it?
  5. Goldenr
    Goldenr New Member
    Phoenix, AZ
    Thank you!
    I used a stock sized antigravity behind the side cowl and tucked most of the electronics there. I have an acewell speedo/tach IMG20240116133931.jpg IMG20231217180917.jpg
    Roast644 likes this.
  6. Goldenr
    Goldenr New Member
    Phoenix, AZ
    Thanks! I'm still figuring things out. Bike didn't run when I got it so didn't have much of a baseline. It has been running well still probably needs some fine tuning.
    Velocity stacks are from Mikes XS. Mufflers were some cheap ones from Cafe racer garage.
    For carbs they have 134 pilot jets I probably need to space the needles up or get shorter ones. I have not done too much digging into it yet it runs well and I'm just putting miles on it.
  7. Goldenr
    Goldenr New Member
    Phoenix, AZ
    Thanks! Yep the previous life was a hard life haha.
    Thanks for all you are doing here. I was on here constantly during the build reading through what you have here.
  8. jayrodoh
    jayrodoh YimYam
    Cleveland
    Great job!! Nice looking bike! Pulling off a radically modified Maxim that looks good is a tough job.
    Goldenr likes this.
  9. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    hi, very nice build, congrats.
    can you tell me where you got the clutch and master cylinder controls from, are they the Chinees ones, and are the clipons standard 7/8in ?
    thanks
    Goldenr likes this.
  10. Goldenr
    Goldenr New Member
    Phoenix, AZ
    Thank you. Controls are off eBay probably Chinese. Clip ons are 7/8 woodcraft bars.
  11. bensalf
    yorkshire ,england
    thats what i thought, my problem is i havent seen any of the Chinese ones that are big enough to operate twin discs, do you know the diameter of the master cylinder bore, most of the Chinese ones are only around 12mm, twin discs require around 14mm --5/8in.
    if yours have the larger diameter i'd love to know the listing name or number,
    if yours are the smaller diameter , do the front brakes feel a little "spongy"
  12. Goldenr
    Goldenr New Member
    Phoenix, AZ
    The listing says
    "16mm cnc master cylinder brake fzr yzf"
  13. Goldenr
    Goldenr New Member
    Phoenix, AZ
    Just did a search and I'm having a hard time finding the one I have.
  14. Melnic
    Is that 134 "Main Fuel Jets" you mean? (stock 750 is 120 if I'm reading the wikidot page correctly)
  15. Goldenr
    Goldenr New Member
    Phoenix, AZ
    Yep sorry main jet.
  16. chacal
    #134 main fuel jets are quite large for that engine.........I would think that it would run rich as all get-out. For your configuration, a size #124 or #126 might be more suitable, with #42 or #43 pilot fuel jets.
  17. Goldenr
    Goldenr New Member
    Phoenix, AZ
    Interesting. I'll pull the bowls off and verify what's in there.Going to pull the plugs as well to get a better idea. I have some 124 and 130 jets I can swap out to get where I need.
