FJ600 fuel injection
Discussion in 'XJ Modifications' started by Sly, May 10, 2019.
  1. Sly
    Sly New Member
    Mckenzie, TN
    I'm looking at a set of R6 throttle bodys to replace the old CV carbs with pod filters since i can't seem to keep the carbs tune set after a ride or 2 it always acts like a vacuum leak but cant find one. I'm looking at a microsquirt ecu with a custom set of intake boots that i can make. I have access to a TIG welder, lathe, and a mill so manufacturing custom intake boots shouldn't be an issue. But is there anything i should watch for like fitment between frame rails or the charging system able to power the units effectively ?
    I was just looking at a set of those on ebay and wondering if they will fit a 550.
  3. Chitwood
    Chitwood Well-Known Member
    Fort Atkinson, Wisconsin
    There is a thread or two about putting fuel injection on an XJ but I dont recall the model or author without searching it out. If I remember correctly there was quite a bit of detailed information that may at least give you an idea of what you would be in for.
  4. Sly
    Sly New Member
    Mckenzie, TN
    Thanks I'll have to look for it
  5. k-moe
  6. a100man
    a100man Well-Known Member
    Bedford, UK
    Don't you also need a load more sensors and a high pressure fuel pump for efi to work properly - it's not for the faint-hearted. Refurbing carbs and the inlet tract is a yard and a half easier IMO.
  7. JPaganel
    JPaganel Well-Known Member
    Minneapolis
    At a minimum, you need two. Three is good. Four is if you want to get fancy.
    I'm not sure 2-3 sensors is a "load", but it is more than 0.
    FP is easy.
    Hard parts of EFI are finding a throttle body that fits and mounting the oxygen sensor - you need to find a good spot and weld in a bung.
    After that, it's just plug in the wires and play with the computer.
    Except for buggered screws, stripped jets, and the thrice-damned floats.
  8. k-moe
    It's all a matter of skillset. I know guys who are very adept at FI who won't touch carbs because they are "too complicated".
    I'm the same way about FI, even though I understand it pretty well. I just hate messing with programming. I can do it, but it's not fun for me.
  9. a100man
    Bedford, UK
    I was tracking this thread...
    xj600-fj600-custom-bike-build-with-microsquirt.77543
    .. which looks challenging to me.
    Maybe only a few sensors then but still hassle, then you have to tit about with maps 'til kingdom come. I can see it sucking up a lot of time if you're a) not careful or b) inexperienced.
