FJ600 Jetting Dilemma
Discussion in 'XJ Technical Chat' started by Hollybrook, Jun 12, 2020.
  1. Hollybrook
    Hollybrook Member
    NoVa, USA
    I have an '85 FJ600 and looking at the jets am a bit confused. The bike is stock except for a K&N air cleaner in the stock air box. It came with the following jets, which are stock as per the factory service manual, in two different locations in the book, so not a typo:
    Mains: #105 (Cyl 1&2), 102.5 (Cyl 3&4)
    Needles: 4CP4 (Cyl 1,3&4), 4CP6 (Cyl 2)
    My question is why have larger main jets in the left side of the engine than the right? And why a different needle only in Cylinder 2?
    If anything, I would think the middle cylinders could benefit from a richer main jet due to running a little hotter.
    Any thoughts?
  2. hogfiddles
    Possibly due to airflow...... some of the 400’s required mixed jets. The Turbo, does, too, I believe.
  3. Hollybrook
    Hollybrook Member
    NoVa, USA
    That would make sense if it was the center cylinders with different carb-to-box boots and position relative to the box geometry, but not left side vs. right side as they are pretty much reverse images of each other.
  4. Simmy
    I suspect a typo, probably should have read 1/4 and 2/3. Never heard of different needles though
  5. Hollybrook
    Hollybrook Member
    NoVa, USA
    After looking at this some more, I think hogfiddles was on the right track. The back half of the airbox with air filter is offset to the left side of the bike with the battery on the right side. Even though there is a large full-width chamber past the air filter, it is being supplied by a port on the left side, so incoming air has a much straighter path to the left cylinders.
    I think Yamaha was trying to maximum performance out of this bike due to competitive pressure from the Honda and Kawasaki and the FJ600 was popular on racetracks in a nearly stock format due to how Yamaha engineered it.
    I am going to play with my jetting some and see what I can learn. I want to go a little richer on the mains and needles to see if I can get it running better. Finding mains is not a problem, but needles are almost impossible to get. After hours of searching on the internet, I finally found a source for 4CP7 needles, which are quite similar to the 4CP6 needle in cylinder 2, but with 5 grooves for a clip. With the clip in the 2nd groove, the needle is leaner than the 4CP6 and it the 3rd groove, it is richer. The taper is the same, so with a 0.6mm shim, it would perform the same. I found these needles at:
    moto-lab 4CP7 needle
    My plan is to go up one size on the mains (107.5 in cyl 1&2, 105 in cyl 3&4) and run the 4CP7 needles with the clip in position 3 for cyl 2 and position 2 for the remaining cylinders. From there, I will tune, see what works the best and report back with results.
    Chacal has been a huge help and I will be sending him an order for parts once I finish going through my carbs and figuring out what needs to be replaced.
    Jetfixer and Minimutly like this.
  6. Hollybrook
    Hollybrook Member
    NoVa, USA
    Just a quick data point. I now have the 4CP7 needles in hand and they are identical to within 0.001" to my USED 4CP6 needle that has 5K miles on it and has been cleaned in a carburetor dip and an ultrasonic cleaner. I also bought another 4CP6 needle off eBay and will compare against it when it arrives.
    The middle clip position on the 4CP7 is the same as the single clip position of the 4CP6 needle.
    At this point, I feel like the 4CP7 needle from moto-lab is an excellent replacement for the 4CP6 needle that chacal recommends on his fuel system pages.
    NOTE: This info supercedes what I said in the previous post that I can no longer edit. That data was from needle info sheets and I feel that my actual measurements are more relevant.
    Minimutly likes this.
  7. xHondaHack
    Orange CT
    Interesting stagger on the jets.
    On a side note, the Fazer 700 has a unique airbox inlet tube set up that requires 102.5 mains on 1 & 4 and uses 105's on the 2 and 3 cylinders. Also, the pilot air jets are 130 on 1 & 4 and 135's on 2 and 3.
    I agree with you that the center cylinders will run hotter temps, whether they're air or water cooled, and need a richer mixture to help with cooling. On my Maxim X, I run 115 on 1 & 4, 117.5 on 2 and 3. Plus some other tricks too.
    They have Mikuni BS33's, so very similar to your's.
    Also, nice find on the "adjustable" needle jets, and I'm sure you'll have fun with tuning. My guess is the stock jetting that Yamaha set them up with has gotta be close. Remember to make only one change at a time to see what improvement you make, or don't.
    If you haven't done them already, valve clearances should be checked, and any vacuum leaks need to be addressed. Don't forget that your ignition system needs to be in tip-top shape too.
    Tony
  8. Hollybrook
    Hollybrook Member
    NoVa, USA
    After many trials and tribulations bringing this bike back from a lack of adequate care and then 10 years sitting in my garage, it is now running and I can begin fine tuning the carbs.
    So far, I have rebuilt the carbs, front forks, replaced or rebuilt everything in the brakes, adjusted the timing chain, checked the valve adjustment, replaced the tires, repaired and cleaned the K&N air cleaner and a bunch of smaller tasks as well as a whole lot of cleaning.
    It seems to be running and riding like it should, so now for the fun of making sure I got the jetting choices correct.
  9. Hollybrook
    Hollybrook Member
    NoVa, USA
    I am coming back to this thread because I have run into a new issue. I have been quite happy with how the bike has been running with the jetting described above.
    Unfortunately, I have a new problem that has appeared over the last month. I first noticed it on an early morning ride where once the engine was started, taking the choke off became difficult because the engine would take longer than usual to support running without the choke. A later warm start was much better, but not quite as easy as usual. I didn't ride the bike for a couple of weeks, and the next time I tried to start it, whenever I started to remove the choke, it would not run. If I revved the throttle, it would run at 3,000 RPM or higher. It finally cleared up enough to try and ride the bike, but it was always quite flat coming off idle with significant hesitation until the revs got up a bit.
    About a week later, I tried again and it was even worse, to the point that I was never able to get it to run without choke unless over about 3,000 RPM.
    Thinking it was likely to be a carb problem, I removed the carbs to take a look at them. I pulled a float bowl to check the enrichment jet in the float bowl. The bowl was clean and the gas looked fine with no sediment at all. The float needle looked good and I did not see anything that was a potential problem. I also pulled one of the diaphragm caps to look at the diaphragm, which was fine. I then did a drop test on the pistons with the carbs fully assembled. They were all equal and took 1-2 seconds to fall.
    So, at this point, I am not sure what might be causing this. It seems like maybe a float level problem, so I am going to bench test that next. They were correctly set using a clear hose when rebuilding the carbs a couple of months ago, so I am not expecting to see a problem there.
    A few months ago, I did take apart my petcock, clean it and reassemble with some spare parts I had on hand. I have noticed a slight dripping when switching between on and prime, so perhaps there might be an issue there that is restricting fuel flow. Since this bike had not run in 10 years prior to my partial restoration, I added a fuel filter to the gas line and it was not showing any dirt. I plan on removing it when putting things back together again, especially since I have never been able to get all the air out of the clear filter.
    Any suggestions for things I should look into are most welcome!
  10. chacal
    You should look inside the little well in the bottom of the bowl with a strong flashlight, to make sure the bottom of the well isn't clogged (this well is where the brass choke tube drops into the carb bowl). Same with the brass tube.....you'll need a thin wire to probe it (them) and make sure they are clear, as well as a tiny hole in the SIDE of the brass tube(s)....an air vent.
    P.S. how do you know when your starter jet is really, truly, zestfully clean? One of two ways:
    a) shine a strong penlight or mini flashlight into the bottom of the bowl, where this jet passage "intake" is located. Look through the top of the bowl down into the jet passage "outflow" passage (this is the passage that the brass suction tube in the bottom of the carb body actually fits down into). Focus your eye carefully on the jet opening and make sure it's clean. P.S. it helps to do all this while in a darkened area.........see the picture "starter-jet.jpg" on page 2 (post #23) of this forum thread topic for a great image of what you want to see!:
    http://xjbikes.com/forums/index.php?threads/4050
    and post #5 on this thread, the starter jets is quite visible on the lower left side of the image:
    www.xjbikes.com/forums/threads/i-think-i-know-why-the-sequel.116988
  11. Hollybrook
    Hollybrook Member
    NoVa, USA
    Len, that was all done when rebuilding the carbs and checked on the float bowl I removed.
    Do you think the symptoms point to an idle circuit problem more than a float level one?
    One thing I did not do when rebuilding the carbs was to replace the enrichment plungers.
  12. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    Don't worry about air in the filter, that is normal. Keep it on for safety if it is the sintered brass type.
  13. Huntchuks
    East Rochester, NY
    I would check the jet in all the bowls first. Make sure something didn't happen.
  14. Hollybrook
    Hollybrook Member
    NoVa, USA
    Done on all four carbs as per Len's procedure above.
    I think this was mostly unnecessary as the carbs were immaculate a couple of gas tanks ago and never run without a fuel filter.
    It seems to me that this problem is affecting all four cylinders, not just one or two.
    One reason I think I need to recheck float levels is that we have E10 gas here and the new float needles I used were NOS Yamaha ones that are from pre ethanol days.
  15. Hollybrook
    Hollybrook Member
    NoVa, USA
    The fuel filter I used is a paper one with a good flow rate.
  16. chacal
    Well, the fuel levels would have to be REALLY low to cause the symptoms you are describing, unless it's really cold outside choke should basically not be needed, at all.........the bike runs off the idle circuit. If the choke tube and bowl wells are clear, then the idle circuit may be presenting some type of issue. Although if you just went thru the carbs recently, and it was running okay before, it's hard to understand how they may have gotten blocked so quickly, but things happen.
    One easy test is to remove the inline fuel filter and try again, who knows, if the choke is getting fuel then the idle circuit should begetting fuel, too.
    Petcock: leave it in the PRIME setting, see if fuel flows and flows (remove hose to carbs), and if so, try the bike with it in PRIME setting, see if that makes any difference.
    Pilot circuits clog up really easily since they are so tiny (internally), maybe you got some bad gas somewhere............
  17. Hollybrook
    Hollybrook Member
    NoVa, USA
    Over the weekend I had some more time to work on this. While I had the carbs on the bench, I checked the wet float levels and all were at 3mm as per the factory service manual. After checking the in-tank filter screens, I removed the inline filter, clamped off the vacuum line (in case there was a leak at the petcock) and set the petcock to prime. None of this made any difference.
    I think it is valuable to go back to the basics at this point:
    1. The bike went from running properly to not being ridable over two short rides a few weeks apart. During this time, there was no gas added and no work done to the bike. The temperature dropped a bit, but not significantly.
    2. The engine will not idle and needs the choke on to run at 2-3K RPM with no load. If you give it throttle, it will rev cleanly once over 4-5K RPM, even if the choke is removed. It is not able to run at all with a load.
    3. The engine revs drop cleanly when letting off the throttle. I am not sure if this is because the mixture is OK, or if it is so far off that combustion can not be supported.
    4. Once the engine has run for a few minutes but not long enough to really warm up, it will idle for a couple of seconds when first started, then stall.
    5. The engine will sometimes idle for 10-15 seconds at no throttle, but at very low RPM and then stall.
    6. The carb bowls are not showing anything other than clean fuel, the enrichment tubes and starter jets in the bowls are clean. I did not verify the holes by the butterflies in the throats, but based on the clean bowls and having a decent fuel filter, I cannot see any real likelihood of this being a problem.
    7. It seems like either all the cylinders are firing with the choke on, or none are firing at all. It also feels like this is happening at 0-1/4 throttle position below 4K RPMs.
    My gut feeling is that this problem is across all cylinders and not carb related. Perhaps I have an intake vacuum leak?
    FWIW, I am the original owner of this bike and it has never been easy to start, always needs the choke for a couple of minutes and I have usually needed to begin my ride with the choke half on. Once it warms up a bit, it has run quite well though I always thought the jets were a touch small, which led to my minor changes outlined above.
  18. Hollybrook
    Hollybrook Member
    NoVa, USA
    I put this on a back burner once the weather got cold and recently started working on it again. I am having trouble blaming this on the carbs as they were properly rebuilt and running correctly with little chance of any new fuel contamination. Before doing anything else on the carbs, I decided to check the ignition system. Here is what I found:
    1. Primary and secondary circuits on the coils were within spec.
    2. The TCI pickups are within spec.
    3. Only one of the plug caps is within spec and the rest of them are flaky. These are the caps with removable resistors and it looks like there has been some internal arcing going on with at least one of them. The resistors are not within spec when removed, so no amount of cleaning will fix this and I will be replacing them. That said, none of the resistance values were so bad that I think they would have kept the bike from running better than it has been.
    I also notice that the #1 cylinder intake manifold did not look like it was properly sealing against the cylinder. I was able to slip a .002" feeler gage though the gap with a little resistance, so it looks like the intakes will have to come off and be resealed.
    Once I get all this done, I will follow up with what I have learned.
  19. Franz
    Just wondering if you checked your valve clearances?
  20. Hollybrook
    Hollybrook Member
    NoVa, USA
    Yes, they were already correct and I adjusted my timing chain at the same time.
  21. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    hi, Hollybrook, just a quick question, whilst you are on with this,
    do you have a description, or photos of the airbox with the KN filters fitted. i am interested in this ,for my cafe racer, which, KN filter is it?
    thanks
  22. Hollybrook
    Hollybrook Member
    NoVa, USA
    @bensalf, I have had the K&N filter since I bought the bike and it replaces the stock air filter in the stock airbox. It is an exact replacement other than having a gauze medium instead of paper. I suspect it is no longer made.
  23. bensalf
    yorkshire ,england
    ok gotcha
  24. Hollybrook
    Hollybrook Member
    NoVa, USA
  25. Hollybrook
    Hollybrook Member
    NoVa, USA
    @bensalf, if you do not want to buy that K&N air filter, please let me know and I will buy it as a spare.
  26. bensalf
    yorkshire ,england
    the air filter will not fit ,in the airbox ,cos the back half has been cut off. my filter (honda 50) now sits inside the first chamber.
    but thanks for yor help
    upload_2022-3-6_23-32-17.jpeg upload_2022-3-6_23-32-17.jpeg upload_2022-3-6_23-32-17.jpeg
  27. Hollybrook
    Hollybrook Member
    NoVa, USA
    Yes, there is no way to use that filter. After what I have learned about airflow through the stock box and seeing how your filter sits in your box, I am wondering about carb jetting. Are you able to use the stock jetting or have you needed to re-jet for the new airbox configuration?
  28. bensalf
    yorkshire ,england
    i did about 100 miles on it, before the weather turned. still on standard jets, but it seemed to run ok, but i didnt give it a lot of stick, i really should dig this machine back out and sort it out.
  29. Hollybrook
    Hollybrook Member
    NoVa, USA
    Well, I was correct about the sparkplug caps not being the problem, nor was the #1 intake manifold. After fixing both of them, I still could not get the bike to run correctly, though I could get close if I ignored the carb synchronizer and tuned by ear. Also, using a colortune, I was unable to get the mixture rich enough to show yellow.
    Being quite frustrated yet again, I decided to take another run at the carbs. Up until now, I have not been able to dip the carbs in a petro based cleaner and only have been using a heated ultrasonic cleaner. Using the petro based cleaner would damage the shaft seals that do not appear to be leaking based on the propane test, though I guess they might be at some times that I am not seeing. Anyway, I got some new shaft seals and also decided to go to the next larger pilot gas jet to see if I could richen up the idle mixture. I noticed that all FJ600s sold outside the USA and Canada used a larger jet size, so with the K &N air cleaner and E10 gas, it makes sense to try the larger jet. I was thinking that I could just turn out the pilot screw a bit further, but the colortune did not show that to be the case.
    At this point, the carb bodies have been cleaned in the petro cleaner and the carbs are ready for reassembly. My wife broke her leg and needed surgery to put in a plate and screws, so my garage time is quite limited for the next month or two. I will report back when I have more news on this project. I hope that documenting this will help somebody in the future with a similar problem, though at this point I have fixed so many things on this bike that sat for 10 years, it is hard to say which ones were critical to getting it running like (better) than new.
    I have to give a big thanks to @chacal for the excellent parts supply he has helped me with, along with some great advice. It is amazing that with all the parts I have looked for him to provide for this low volume, 37-year old bike, only one circlip has not been in stock! I truly believe that without his help, this would have been an exercise in futility.
    Jetfixer and Huntchuks like this.
  30. Jetfixer
    I have used K&N filters in my cars , HOWEVER my beloved Seca had a K&N the PO had put in , he also claimed carbs were professionally tuned. It had three different spark plugs, it ran kinda soggy is best , bogged when you took off . I put correct spark plugs in was a little better , took carbs to church could not get it to run quite right , took out the K&N filter put stock paper filter ....OMG it was hold on tight bike screamed . So not sure why the difference but this was my experience.
    Hollybrook likes this.
  31. Hollybrook
    Hollybrook Member
    NoVa, USA
    @Jetfixer, I appreciate your feedback.
    This bike has run well since I bought it in 1986 and it has had the K&N air filter since the first time I needed to change it, probably 1986 or '87. That said, it has always been on the edge of running lean, though performance has been good.
    While my brother had it for a bit over 10 years in Florida, it began to not run as well and even though he is an excellent mechanic, he took it to a shop because he was too busy at the time. They cleaned the carbs and drilled out the pilot screw caps to tune it up. He says that it ran OK after that. That was also about the time that the US decided that E10 was a good idea, so there is the good possibility that much of his problems related to the engine already being jetted lean to meet emissions, adding a better flowing air cleaner, and then a fuel change that resulted in even leaner combustion. Each change I have made for richer conditions has resulted in better running for that particular area of throttle/load/RPM, so I think I am on the right track.
    When I got it back from him, it had sat too long and was not running. Each time I have rebuilt the carbs without dipping the carb body, it has run OK for a tank or two of gas and then quickly gone downhill. I have been rebuilding carbs on bikes and cars since I was a teenager and rarely had to redo any of them. I also used to successfully tune and race a Datsun 240Z with SU side draft carbs that are quite similar in concept to the CV carbs we all have. I am now hoping that actually dipping the carb body and replacing the throttle shaft seals will resolve any remaining problems that I am having.
    This has been a quite frustrating and humbling experience, but as they say. you get stronger when you confront adversity!
  32. chacal
    I believe this explains most of the symptoms you were experiencing. Also note that leaky throttle shaft seals will add additional "leanness" to the engine.
    Jetfixer and Hollybrook like this.
  33. Jetfixer
    If you have not replaced the butterfly seals , Len carries these and are worth the investment. Thanks to xj4ever I have done three sets of carbs , this rules out this as a vacuum leak.
  34. Hollybrook
    Hollybrook Member
    NoVa, USA
    Yes, I am replacing the shaft seals with ones from Len. I have never been able to find a vacuum leak at the shafts, but there is no guarantee that I don't have one in some situations. In any case, this did allow me to do a more aggressive cleaning of the carb bodies which never hurts.
    The seals I took out were not that bad, but the lips seemed a bit stiff, so new ones should be better.
    Jetfixer likes this.
  35. Jetfixer
    See my post on why you should replace you butterfly seals, one set of carbs I did they litterly were like gum. Another set I did for someone else, the seals were actually packed with RTV .
  36. Hollybrook
    Hollybrook Member
    NoVa, USA
    Well, I now have the bike running again, and much better! I can't really say if the new shaft seals made a big difference as the ones I took out were not that bad, but knowing that I have new ones is one less thing to worry about. I also noticed that when I reinstalled the butterflies, they fit better and did not bind on the throttle bodies. Since the screws were peened over from the factory, this was an item that was OK but not perfect, though I cannot see that it made any significant difference.
    The bike starts much better, which I attribute to the larger pilot gas jets. I still cannot get a yellow flame on the Color Tune, but do see a nice blue one. I ended up synchronizing and just setting the pilot screw by ear. If anything, the bike seems a touch tamer to me, but I recently got a Tenere 700 and its high torque engine may have spoiled my recollection of how this one accelerated.
    I was quite surprised to find out that the FJ will start without the choke -- this never was possible from the day it rolled off the dealer's floor. Again, a huge thanks to @chacal for all his support, parts and advice!
  37. Hollybrook
    Hollybrook Member
    NoVa, USA
    I want to document where I ended up in case anyone else is on the same journey to keep one of these bike running on E10 fuel. While the final settings might be slightly different, this should make a good starting point.
    My final settings were:
    All other settings are the same as stock including float bowl fuel level.
  38. Hollybrook
    Hollybrook Member
    NoVa, USA
    Just checking in to say the FJ600 continues to run great as set up in the previous post.
    chris123 likes this.
  39. Hollybrook
    Hollybrook Member
    NoVa, USA
    And it is still running fine.
    chris123 and a100man like this.
  40. chris123
    chris123 Active Member
    Benicia, ca
    Excellent thread!
    I have two yx600’s, which are very similar to your FJ600. After rebuilding three sets of carbs I’m getting ready to play with needle and jet settings to get these things running.
    The yx600 comes with bs30 carbs from the factory - all with 97.5 main jets. Cylinders 1 & 4 use 4CHP2 needles and cylinders 2 & 3 use 4CHP4.
    Derick Capito (Yx600 Guru) recommends 100 main jets and 4CHP7 adjustable needles set at the third position from the top.
    Like yourself I figured I’d put this information here for future readers.
  41. Hollybrook
    Hollybrook Member
    NoVa, USA
    2 1/2 years later, this bike continues to run well, though it very quickly became harder to start after the final carb job and changed jetting. I have to use full choke even in warm weather and it is slow to warm up, just as it has been since new. Some of this may be due to the limited riding I do on it, since I have other, more modern street bikes that I don't mind running up the miles on.
    I remain indebted to @chacal for the parts and advice that got me to this point!
