Float level verification using fuel and clear tubing
Discussion in 'Hangout Lounge' started by H0ckenut, Mar 25, 2012.
  1. H0ckenut
    H0ckenut New Member
    Waterford, NY
    Does anyone know if there is a tutorial out there on how to verify the float levels using clear tubing (preferrably one with some pictures)? I am following Fitz's list. I checked and adjusted the valves, cleaned and rebuilt the carbs so that they passed the clunk test, now I still have them off the bike and I am ready to adjust the float levels.
    Thanks in advance for any advice.
    Jeff
  2. schmuckaholic
    California
  3. bigfitz52
    Keep in mind that the articles referred to are done on Hitachis. The method is exactly the same, but the spec is different for your Mikunis.
    For the Mikunis, the spec is 2mm +/-1mm below the "the carburetor mixing body edge."
    PM me with your email address and I can send you the diagram from the factory book if you don't have one. I think the diagram is repeated in the Clymer too.
  4. Bobbybonez
    Bobbybonez Member
    Sioux Lookout, ON
    Thanks for that. I will be attempting this today.
  5. schmuckaholic
    California
    Specs for all carb models are listed at the end of the file, Fitz.
  6. H0ckenut
    H0ckenut New Member
    Waterford, NY
    Thanks for the replies. I will be getting started on this once it warms up again in my garage. It was 80 degrees here last week and now it is going down into the 20's. I can't wait for this weather to make up it's mind!
    Jeff
  7. bigfitz52
    I know. I've had a couple of instances of people looking at the pictures but not actually reading my articles. Just pointing it up.
