Float Levels
Discussion in 'XJ Technical Chat' started by Kendall, Apr 19, 2009.
  1. ManBot13
    ManBot13 Well-Known Member
    Fairfax, VA
    Saw some pics here for a set-up for measuring float level and thought I'd submit my own: Take two pieces of wood (I use a 2x6 and 2x4) and screw them together with 2 drywall screws. Then set the carbs on them and figure out where to put two more screws that will sit under bowls 1 and 4. Hand screw these in, and use them to level the carbs. Put this on a level desk or shim as appropriate.
    This set-up is low and allowed me to just stack a couple of bricks and set a snow-blower tank up behind this mount. Keep-in-mind that the carbs are not *mounted*, and will fall off if you bump the desk.
    Enjoy!
    *snow blower tanks make excellent test tanks, they're small, made to handle fuel and have a valve built in.
  2. yamaman
    yamaman Member
    Staten Island, NY
    Midnightblu, this may be an off day for me but, thats a pic of the needle valve, where's the bend in the factory float? Thanks
    Anthony
  3. bill
    bill Active Member
    Raleigh, NC
    ManBot13 - neat jig - simple - easy- functional.
