Forcing fuel cap lock
Discussion in 'XJ Technical Chat' started by a100man, Jul 29, 2017.
  1. a100man
    a100man Well-Known Member
    Bedford, UK
    Lost a bunch of keys yesterday that included the fuel cap key on my 550. I have another cap and key that was going to replace it with one day and now that has been forced on me. So what's the best way to force open the current cap?
    Cheers
  2. Toomanybikes
    Tsawwassen bc
    Lock picks if you can get them.
    Or fashion some out of split pins. Hammer one end flat and bend it 90 degrees, this is your turn tool. Do the same to a second one and grind it thin like a key and put an S bend near the end.
    Now having a second person to put downward pressure on the cap to release pressure on lock and work the pins inside while turning the tumbler.
    Lots of graphite in lock first or any lube that it thin.
    If you can harden these tools with heat (cherry red)and quench them in oil
    If that fails go to a locksmith and it's cheaper than destroying your tank and cap.
    Just did it on an old tank an took 40 seconds
    Stumplifter likes this.
  3. a100man
    Bedford, UK
    Interesting. Not convinced I have the talent for that but I do know a locksmith. I don't mind trashing the cap but the tank is another matter..
  4. Toomanybikes
    Tsawwassen bc
    First time I tried it took an hour second time 10 min now most locks 30 seconds or less.
    Patience Grasshopper
    Posted a video on Facebook look up
    Toomanybikes
    a100man likes this.
  5. a100man
    Bedford, UK
  6. Simmy
    Just hammer a flat screw driver into the key hole and turn it using some muscle. Drill into the lock with a 1/4" bit first.
  7. a100man
    Bedford, UK
    I think hammer and screwdriver will be plan B. Right now I'm on teh picking trail. I have some old hacksaw blades and a bench grinder..
  8. a100man
    Bedford, UK
    Well I'll be blowed.. Just broke into my own house with these..[​IMG]
  9. Polock
    go find your keys
  10. a100man
    Bedford, UK
    Yes indeed, still active on that front too.
  11. steber
    steber Active Member
    Scranton, Pennsylvania
    Same boat, I think I'm just going to run my ignition over and have a lock smith make me a key from the code.
    Chitwood likes this.
  12. a100man
    Bedford, UK
    Just watched your video - thanks! So you only need to run the pick up and down one side of the key-hole then? Given that the key is 'double-sided' compared to a house key I thought you might have to do both sides.
  13. Toomanybikes
    Tsawwassen bc
    No just one side
    Lever tool in forward part of slot
    Pic in rearward part of slot
  14. steber
    Since the tank is the only one using a key, I went ahead and did this. Came right off, just be careful of metal shavings, you don't have to drill through the whole lock, just the tumbler
  15. chacal
  16. Toomanybikes
    Tsawwassen bc
    Just don't let the popo catch you with them. Some places will toss you in the clink just for possession of "tools of crime"
  17. Simmy
    I recently bought a Chinese re-manufactured gas cap complete with a set of keys.
    Looks to be of equivalent quality to the OEM, I think it was about $15.
  18. a100man
    Bedford, UK
    Indeed so but first you got to get the old one off. In fact there's a surprising amount of information ( and vendors) on lock picks ( thanks also to Len for the link). I have practiced on a spare cap I have at home. Later in the week I'll get over to my bike store and try a new pick on the actual target as my keys have not shown up..
  19. a100man
    Bedford, UK
    Ok - just to wrap this up. The keys haven't shown up in spite of extensive research and back tracking of steps. So last night I visited the bike with a newly fashioned (from old hacksaw blade) 'Bogota Rake' a couple of minutes later and Bob's your Uncle! Replaced cap with a spare I had and jobs a good 'un.
    My only issue now is three keys one each for ignition, cap, and seat. I've heard its possible to dismantle locks and rearrange teh pins to suit a single key - but that sound real tough!
    PS Many thanks to toomanybikes fo his inspiration and insight.
  20. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    Love to see pics of your picks/ tools!
    I had a situation with a garage door - keys weren't lost, they were four hours away. Tried to make some picks from some metal banding strap - thought I understood the concept (same link from above) - but just could NOT get that simpleton of a lock open..... :oops:
  21. a100man
    Bedford, UK
    Yeah it's interesting.. I practiced on my spare cap and couldn't get it open the 'snake' style pick in the photo in the 7th post above.. I then made a simple one in the 'half diamond' style that would open it but it took a while and was annoying. The improvement, I think, came with the last one I made (Bogota Rake style) - you can Google for templates believe it or not. You also need a good 'tensioner' that is small but strong enough to provide the twisting force without bending.
  22. jayrodoh
    jayrodoh YimYam
    Cleveland
    Yup, there are tutorials on line or you can take to a locksmith and they will do. Fairly inexpensive and they will have all the extra pins in case what you have between the two locks is not enough.
  23. XJ550H
    the links from xj4ever how to's covers pin removal and or cylinder swap
    Clean and lube the ignition switch
    Your Gas Cap and You
  24. a100man
    Bedford, UK
    Thanks - does look like plenty of opportunity to foul things right up! I do have an old ignition to take apart though..
