Fork Damper Rod Removal
Discussion in 'XJ Technical Chat' started by bunglejyme, May 16, 2010.
  1. bunglejyme
    bunglejyme Member
    New Jersey
    I am doing work on the fork assembly of my 1981 XJ650H. While I am at it I wish to replace the fork seals but need to remove the Damper Rods.
    I am working out of a Haynes workshop manual and they show a home-made adapter; however, they provide no details such as the size.
    Since the Damper looks like it has a hexagonal socket I assume that an allen wrench on the end of a long extension bar would be the tool to use. The problem is I cannot determine what size the hex recess is in the head of the Damper rod as it is deep inside the stanchion. Anyone out there ever performed this operation? Would you know what size the recess is in the Damper?
  2. ManBot13
    ManBot13 Well-Known Member
    Fairfax, VA
  3. RickCoMatic
    The "Universal Fork Damper Tool"
    For ALL Yamaha Bikes
    Steel Rod:
    60cm Long
    12mm Diameter
    19mm Hex Nut -- Welded to one end.
    22mm Hex Nut -- Welded to other end.
    19mm Hex |<------60cm Rod------>|22mm Hex
    Grind the Rod to fir the Hex Nuts.
    Weld Nuts to Rod
    Dress welds flat.
  4. TMHack
    TMHack Member
    Green Bay, WI
    The internal on mine which are off of a 650 turbo were 22 mm. I just took a spark plug socket and tunred it around. the 1/4 drive extension fits into the open end and then I just added extensions to reach the end of the tube so I could put a ratchet on it.
    Rick's Universal fork dampener tool sounds like a good idea though. Might have to build one of those.
  5. Hillsy
    Hillsy Member
    In the shop we used to keep the forks assembled, clamp the caliper mount in the vice (so the fork is horizontal) then undo the damper bolt with an air gun. The tension from the fork springs keeps the damper rod from spinning, and the entire job is a 5 second one :wink:
  6. gunnabuild1
    gunnabuild1 Member
    I did the same as TMHack turned the spark plug socket around and used extension for the depth stuffed some rag into the plug socket to keep it all tight worked first time exactly the way I was hoping for.
  7. bunglejyme
    bunglejyme Member
    New Jersey
    I wish to thank you all for your suggestions. I'll see what I have around the shop to make one of these tools. Thanks again guys.
