Fork Pressure
Discussion in 'XJ Technical Chat' started by Tim O, Aug 4, 2018.
  1. Tim O
    Tim O Active Member
    Charlottesville, VA
    I mentioned in another post... but just wanted to put up here I can't believe the improvement in bike handling since changing a few settings on my forks. I'm now running 18 psi and I turned the anti dive 1/2 turn out compared to fully closed as the PO had it. If it starts to feel harsh I pull out a couple psi.
    I think I had seen in another source that had typos that the MAX pressure was 5.7 psi for my 82 Seca 750. And I had been running 5 psi.
    Then I saw the Haynes says 17psi... but I also thought it curious that the UK model is same springs and dimensions but max 36 psi operating and also the Americas versions Max and range are different numbers. I'm wondering if it's another typo?
    Anyway... she RAILS in the corners right now.... don't forget these settings when doing checks or bringing a bike home :)
    For comparison, I'm 5'10" - 220lbs.
  2. Rooster53
    Curious as I haven't seen it addressed here, but is that the pressure on the centerstand with the forks fully extended or with the wheel on the ground and the forks slightly compressed from the weight of the bike? It seems it makes a big difference in the measured PSI and it would seem fully extended would be the correct checkpoint for consistency.
    Just for reference the Yamaha FSM specifies the standard pressure as 5.7PSI, but notes during fork rebuild not to exceed the maximum of 36 PSI, both of which match the data you posted.
  3. k-moe
    That is one of the tables in the Haynes that is correct. What you set the forks at will depend greatly on your weight, what you have onthe bike in tems of luggage (if any), and what the roads are like. I set mine quite differently for touring than I do for just riding around.
  4. kerriskandiesinc
    NY
    Curious if the extra air pressure will wear out the fork seals quicker.....
  5. maybe4
    maybe4 Member
    Chicago Area
    according to the owners manual......."when checking the air pressure there should be no weight on the front end of the motorcycle"
    Rooster53 likes this.
  6. k-moe
    It will not. Exceeding maximum pressure will force oil past the seals though.
    kerriskandiesinc likes this.
