forks bent?
Discussion in 'XJ Technical Chat' started by c_stuckel, Feb 18, 2009.
  1. c_stuckel
    c_stuckel New Member
    I have a 1982 jx 650 seca and when i got it the guy that got it from told me that the bike was dumped. But i dont know if it was moving or if he just droped it. It does have some road rash so i think it was moving. He said that the forks might be bent. Is there any was that i can see if they are bent without removing them?
  2. wizard
    No, the only real way is to take the chrome tubes out & roll them on a flat surface, like glass, any distortion will show up.
    The good news is they can be straightened.
  3. Polock
    if you loosen the bolts on the triple clamps with the wheel off the ground and try to spin the tube it should spin and not bind half way around
    if you have air forks that might not work
  4. c_stuckel
    yes they are air shocks. where do i get the pressure that should be in them?
  5. wizard
    5.7 psi
