Found with flats at boneyard..rode her home for a cnote!
Discussion in 'XJ Modifications' started by remo, Jul 26, 2017.
Tags:
CHOP OR STOCK?
  1. Chop
    2 vote(s)
    16.7%
  2. Keep stock
    10 vote(s)
    83.3%
  1. remo
    remo Member
    Northern New Mexico,usa
    Screenshot_2017-07-26-04-41-29.png Bike came complete needed gas, battery, carbs cleaned... (thanks rickomatic) the bible was engrained that part came second nature after we limped 30 miles home on maypops with a lawn and garden battery strapped to the seat. We have been adding to the 22k she came with. Enjoying the luxuries of speedometers, mirrors, front brakes, a front fairing and other bells &whistles often taken for granted. Quite reliably for about a year, allowing my frankenbike 550yics the chance to gather dust. until oneday last week 100 yards out the driveway she just quit. Like something hit the kill switch. Now no spark. Hmm not sure what to do with all the stock wiring...? I guess its time to go over the electrical troubleshooting write up again. I sure hate to take off all the pristine stock parts that have probably never been peeled back and seen the light of day!
  2. cgutz
    cgutz Well-Known Member
    SE South Dakota
    If it just completely died, check your fuse box. Clips may be corroding/crumbling. Happened to my XJ550 and it just died suddenly at an intersection.
    Chitwood likes this.
  3. k-moe
    Sidestand switch.
    XJ550H and Chitwood like this.
  4. Jetfixer
    Keep stock fewer around:(
  5. cruzin
    cruzin Active Member
    Michigan
    Nice find
  6. XJ550H
    remove your sidestand safety relay to check the sidestand swiitch . clean it anyways.
    does bike turnover with no spark?
  7. remo
    remo Member
    Traced the source of the problem down. Was indeed something to do with sidestand relay, however the ignitor was gettin hot and failing to supply a dependable spark. So tell me this :why does the ignitor off of my xj 550 seem to make the bike run better than before? It seems like a 750 ignitor wouldn't work on the 550. If I remember correctly. My ignitor was mis -categorized as a 750 part on ebay but I nabbed it up because I noticed it had the right color label for 550. Are they compatible one way?
  8. remo
    remo Member
    Oh ya thats what I fixed first at the boneyard. It must have been overlooked because when I asked if they had a pair of glasses I could use for the ride home. They looked at me like I had 18 heads ! Classic!
  9. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    Imagine the looks if you had done the tinfoil fix!
  10. XJ550H
    the ignitors will swap and work to start any of the yics bikes . they just will not run correctly. timing issue.
    Iwe had a member with a 550 using a 750 tci bike ran but not well untill he got the correct tci unit.
    iirc the non yics tci ignitors are wired differently at the connectors in the harness and will only work in the non yics bike
    what are the numbers on the mis cat tci?
  11. remo
    remo Member
    Also I found something interesting when I went over the wiring. On one of the connectors to the relays, I believe it was the sidestand or starter I noticed three wires were brass blade terminals and one was silver. Same on the relay except the orientation was mismatched ie the silver was getting a brass terminal connected to it. I switched it around not sure if it matters. The miscat tci was a 4-u8 somethin...
    ill snap a shot when I get home.
  12. XJ550H
    4u8 is 550 parts
